optima battery #602758
02/03/10 07:32 PM
02/03/10 07:32 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
I am looking to change my conventional car batteries for a red optima, what model should i go for, will the red be sufficent.
440 motor 12.5.1 comp.
Mick
Re: optima battery [Re: deaks] #602759
02/03/10 07:35 PM
02/03/10 07:35 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Does your car have an alt? If not I would use the yellow. (that's what I have)
If it does then the red should be fine.
Re: optima battery [Re: WILD BILL] #602760
02/03/10 08:45 PM
02/03/10 08:45 PM
Mooresburg, Tn
'72CudaRacer Online content
Happy Birthday '72CudaRacer  Online Content
Mooresburg, Tn
I run no alt, but have 2 red tops. I have made 11 passes in one day before putting a charger on it, including cooling down and cranking up at trailer and 3 or 4 times in the staging lanes. Now that I think about it, I had to swap a battery out before semi finals that nite, but I was running two classes. 1/8 mile, MSD 7AL2, line locks ect.
Brian
Re: optima battery [Re: '72CudaRacer] #602761
02/04/10 03:20 PM
02/04/10 03:20 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
I run the stock dual field alternator.
Mick
Re: optima battery [Re: deaks] #602762
02/04/10 04:21 PM
02/04/10 04:21 PM
Renton Washington
Triple Threat Offline
Renton Washington
You'll probably either want a bigger alternator, or if the car is mostly used on the strip, I would install a yellow top.
I run a stock alt and a single red top and if I run my fan a bunch between rounds it will kill the battery. I had to get a jump more than once in the pits last year to make it back around for the next round. I'm adding another red top or a different alternator for this season. Might even do both to be safe.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: optima battery [Re: Triple Threat] #602763
02/04/10 04:56 PM
02/04/10 04:56 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Based on my 13:1 SB, I see 2 batteries and an alternator in your future. My car likes the additional weight in the rearend anyway. One battery of any type was iffy, and without an alternator, no way.
Oddly enough though, my 10.8:1 Street Hemi gets 5-7 years out of an Optima red top with no problems.
I'm sure someone else's experience will contradict mine, but a racecar that won't start makes me livid.
Re: optima battery [Re: Triple Threat] #602764
02/04/10 05:00 PM
02/04/10 05:00 PM
Lehigh Acres, Florida
rickstershemi Offline
You couldn't give me an Optima Battery these days....get yourself an Odyssey PC1200 I run all the electronics, fan, No Alternator, with (1) PC1200 and it's Five years old and has never let me down
565" 15-1
Rickster
Post deleted by Defbob [Re: rickstershemi] #602765
02/04/10 05:20 PM
02/04/10 05:20 PM
Re: optima battery #602766
02/04/10 06:22 PM
02/04/10 06:22 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
Here is another bad luck with Optima lately, I finally gave up on them, have one old one that just won't quit, and I used to swear by them, but the last two years I've had nothing but trouble with two I bought, I finally gave up on them when the guy at the Parts store got tired of exchanging them every two or three months and offered to just give me cash credit toward any other battery he stocked, I took him up on that deal. I believe the quality has dropped on them in the last couple of years.
Re: optima battery [Re: wyoming] #602767
02/04/10 06:36 PM
02/04/10 06:36 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
I've just bought an HHR fan and a meziere water pump, so will need something reasonable.
Rickster
Just looked at the pc1200, quite impressive.
Mick
Re: optima battery [Re: deaks] #602768
02/04/10 06:54 PM
02/04/10 06:54 PM
Rickster
Mick
Not sure if it's the dry-cell construction or what, but it will sit for months and crank right up....it sat for two years in the roller and never charged it when the bullet went in it cranked right up. And it's very light taboot
Rickster
Re: optima battery [Re: deaks] #602769
02/04/10 06:58 PM
02/04/10 06:58 PM
Portland, Or.
Bee4spd Offline
Bee4spd  Offline
Portland, Or.
I will add to the Oddysey statements. They are great batteries. I go for months without starting my Bee, it(the Oddysey) still turns the engine over every time. Even through the priming stage.
Re: optima battery [Re: deaks] #602770
02/04/10 11:35 PM
02/04/10 11:35 PM
Sydney, Australia
B-STUNG Offline
B-STUNG  Offline
Sydney, Australia
Red tops, like many other non deep cycle batteries will not last many cycles if used without an alternator.
Yellow tops are deep cycle batteries, and can be used without an alternator.
FYI: I have a yellow top Optima in my Coronet that is 10 years old this month and still going strong.
The quality now is not what it used to be. The last 3 red-tops I purchased lasted less than 1 year. I won't be buying any more.
Re: optima battery [Re: deaks] #602771
02/05/10 12:07 AM
02/05/10 12:07 AM
Rather be in Fallon, Nevada
RussW Offline
super gas
RussW  Offline
super gas
2 Red top Optimas with a 140 amp GM alt, they sit in the car all winter , no issues last 4 years.
Post deleted by Defbob [Re: RussW] #602772
02/05/10 12:15 AM
02/05/10 12:15 AM
Re: optima battery #602773
02/05/10 06:08 AM
02/05/10 06:08 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
I got a 105 amp single wire alt and two bosch 65A/H sealed lead acid in the boot (trunk). They weigh a ton but do help with weight distribution
Re: optima battery [Re: Tig] #602774
02/05/10 07:09 AM
02/05/10 07:09 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I'm not a big fan on running 2 batteries... a battery
is a storage device.... I run a single lead acid
production type battery WITH a alt(80a).... if it
isnt working then you need a better battery or a bigger
alt... if the car cant start in 5 seconds you should
fix the problem.... some of the guys are using the
added battery for weight and thats fine and dandy but
you could do the same thing with lead bars farther
back to do the same.... any ways, to each their own.
I have heard some bad things about the Optima batteries
in the last few years... at Chrysler we use to use
them as a production battery and changed due to a
high warranty on them
Re: optima battery [Re: MR_P_BODY] #602775
02/05/10 07:58 AM
02/05/10 07:58 AM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
I run a Yellow top in my Challenger with no alt. Charge in between rounds and run two classes. I run electric everything. Have had this battery for a season and a half.
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: optima battery [Re: Jacob Pitt] #602776
02/05/10 08:27 AM
02/05/10 08:27 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I sell batteries and have seen a huge reduction in the Optima warranties over the last year or two. I think it has to do with a new plant they built just recently.
There is an Optima internet relations guy that I am surprised hasn't stopped in here yet. He appeared on a jeep forum I am on when there was a thread bashing them. He had some good answers and was very profesional. I guess he monitors google for optima bashing maybe
I have had a red top in my Jeep for 3 years now with no trouble. I will be going with a yellow top in my Barracuda.
68 Barracuda Formula S 340
Re: optima battery [Re: Bad340fish] #602777
02/05/10 10:33 AM
02/05/10 10:33 AM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
I've got a total of 7 Optima batteries. Two red in the racecar (8 yrs old), two in boat one yellow one blue), and three in the motor home. The only one I've had trouble with was a red top that I used for the MH engine. It only lasted a year but got replacement for free. New one doing fine.
