is the return fuel line necessary #602663
02/03/10 05:49 PM
02/03/10 05:49 PM
fresno
hyefatman Offline OP
fresno
on a big block mopar or it it just for smog?
Re: is the return fuel line necessary [Re: hyefatman] #602664
02/03/10 05:52 PM
02/03/10 05:52 PM
Wilmington, NC
donbarnes Offline
Not THAT Don Barnes!!
donbarnes  Offline
Wilmington, NC
I just put mine back in in stainless on my smallblock A-body on the assumption that the fuel tank needed that line for venting , I didn't see any other form of tank vent on mine..
Re: is the return fuel line necessary [Re: donbarnes] #602665
02/03/10 06:01 PM
02/03/10 06:01 PM
fresno
fresno
this is the line that goes from the fuel filter
back to the gas tank
Re: is the return fuel line necessary [Re: donbarnes] #602666
02/03/10 06:01 PM
02/03/10 06:01 PM
CA
Steve383 Offline
Steve383  Offline
CA
Are we talking a fuel injection system or a carb?
Mechinacal pump or Electric?
Where is the fuel filter located exactly and the year / model of vehicle would also be helpful.
Re: is the return fuel line necessary [Re: hyefatman] #602667
02/03/10 06:03 PM
02/03/10 06:03 PM
N
newem Offline
newem  Offline
N
It helps eliminate vapor lock.
Re: is the return fuel line necessary [Re: newem] #602668
02/03/10 06:15 PM
02/03/10 06:15 PM
fresno
fresno
carb --vapor lock ? i do not have the line on my
340 or 318 or 383 cars
Re: is the return fuel line necessary [Re: hyefatman] #602669
02/03/10 06:27 PM
02/03/10 06:27 PM
N
newem Offline
newem  Offline
N
I think they were only used on the 440's and Hemi's. At least in 1970 they were.
Re: is the return fuel line necessary [Re: newem] #602670
02/03/10 06:49 PM
02/03/10 06:49 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
It's a vapor seperator, helps prevent vapor lock and sends the fuel vapors back to the gas tank. You can eliminate this piece and the return line but I would not suggest it.
Re: is the return fuel line necessary [Re: hyefatman] #602671
02/03/10 08:36 PM
02/03/10 08:36 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
They were used on the bigger engines that needed higher volumes of gas,they were more prone to vapor lock.
It a great thing to have with any size engine exspecially with todays gas.
