Re: 904 or 727 [Re: Otherlane] #602517
02/26/10 11:59 AM
02/26/10 11:59 AM
OH--IO
3
360904 Offline
360904  Offline
OH--IO
727
Re: 904 or 727 [Re: daniel_depetro] #602518
02/26/10 12:00 PM
02/26/10 12:00 PM
east coast
Otherlane Offline
Otherlane  Offline
east coast
To switch from a 727 to a 904 and pick up a .15 is good but how much is the cost to do it? I had the option last year to switch but I didn't just because I had a fresh converter but need a good trans. the 727 was cheaper than a 904 but than I had to buy a $1000 converter was worth it to me.i have a friend that love the 904 but couldn't get a good one built for a low 10 truck so now he running a 727.
Re: 904 or 727 [Re: Otherlane] #602519
02/26/10 01:38 PM
02/26/10 01:38 PM
412 SB Duster Offline
I run low 10s with a 904 That I payed no more then 650.00 for all ready to run. Had TA change the hub on the 727 converter 250.00. It's not big dollars to go to a 904. That's cheap for .15
Re: 904 or 727 [Re: Otherlane] #602520
02/26/10 01:42 PM
02/26/10 01:42 PM
Sterling Heights, Michigan 483...
daniel_depetro Offline
In my case the point is moot, because as of right now we are running a bone stock 1974 T/F-727 in the supercharged Dart.
I know it isn't ideal, and yes I mean bone stock. Pulled the engine/transmission out of a 1974 Dodge truck and put them in the car (1972 Dart).
Then we slapped a 144 B&M supercharger (on top of a slightly modified Holley street Dominator aluminum single 4-bbl. intake manifold), 750 cfm Holley carburetor, my buddy sold us a gently used reproduction 340 camshaft/matching valve spring/roller timing set for $75.00 and we installed the brand new set of Hooker Competition headers that came with the car when we bought it. The car has electronic ignition with a cheap Accell Super Coil.
Anyways my dad wants to race it a few times this coming year so we were looking at building a good transmission for it. He is a transmission rebuilder by trade, but hasn't built much performance stuff.
I just figured if a 904 is "better", that's what will be going in the car.
Either way we have to buy all the parts and a converter for either transmission.
I'm also not a big fan of having to put out money for the billet drum in a 727.
1969 Dodge Super Bee A12 (440 Six Pack, 4-speed, Dana 60 4.10)
1972 Plymouth Road Runner (400, 4-speed, 8.75" 3.23)
1974 Plymouth Duster 360 (360, 4-speed, 8.75" 3.23)
Re: 904 or 727 [Re: daniel_depetro] #602521
02/26/10 02:39 PM
02/26/10 02:39 PM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
What about going from a mostly stock 904 to a rollerized 727 behind a small block? If the 727 had all aluminum and light weight stuff and the 904 didn't what would be faster?
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: 904 or 727 [Re: Jacob Pitt] #602522
02/26/10 04:20 PM
02/26/10 04:20 PM
east coast
Otherlane Offline
Otherlane  Offline
east coast
412 how faster is your car with the 904?
Re: 904 or 727 [Re: Otherlane] #602523
02/26/10 04:35 PM
02/26/10 04:35 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
paid 300 dollars for turbo action 8 inch converter...rebuild 904 myself for 300 dollars..used valve body from 727 that i already had...
nothing near 1800........
Tony
70 AARCuda Vitamin C
Re: 904 or 727 [Re: Jacob Pitt] #602524
02/26/10 04:54 PM
02/26/10 04:54 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I had my 727 rollerized, aluminum drum, etc, etc, and replaced a stockish 727 with this new trick one on consecutive weekends..i saw exactly zero difference ET wise.
A 904 with most often be about 1.5 tenths quicker than a 727
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: 904 or 727 [Re: B3422W5] #602525
02/26/10 06:13 PM
02/26/10 06:13 PM
Renton Wa
topfueldart Offline
topfueldart  Offline
Renton Wa
That would've had me hot! 904 here! Stock rebuild. Flex Band, 4 clutches. Shift kit, 500 horse, 500 torque, mid 11's in a 3550 lb car with no issues.
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
Re: 904 or 727 [Re: topfueldart] #602526
02/26/10 06:15 PM
02/26/10 06:15 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Your right, i expected to see SOMETHING, but after reading many posts on here over the years, other guys who did the same thing havent seen anything either.
that said, the reliability has been super
1.41 best 60 foot
6.56 at 104.17
Re: 904 or 727 [Re: topfueldart] #602527
02/26/10 07:03 PM
02/26/10 07:03 PM
That's awesome!
Re: 904 or 727 [Re: B3422W5] #602528
02/26/10 07:06 PM
02/26/10 07:06 PM
east coast
Otherlane Offline
Otherlane  Offline
east coast
AARcuda. first thing I was talking about new stuff and everyone like u cant rebuild trans or having parts laying around.in my case for me to switch to a 904 was a lot of money.the 904 race trans was $2300 plus another $1000 converter.$3300 for .15 NOPE. or 2100 for a race 727 and I had a converter. But I got a race trans for $1800. To me I would rather put a glass bumper on my car for $150 and pick up a tenth and have a worry free 727.But my car should run low low 9s too
Re: 904 or 727 [Re: Otherlane] #602529
02/27/10 10:16 AM
02/27/10 10:16 AM
At 3280 W/D it's been 10.07 @ 132 nothing fancy.
It should go 9.90s this year with no changes to the trans.
Al
Re: 904 or 727 [Re: 412 SB Duster] #602530
04/01/10 12:05 PM
04/01/10 12:05 PM
ms
W
w2dak394 Offline OP
w2dak394  Offline OP
W
ms
what years were the 904 non lock in production? can anyone recommend a builder close to MS?
