Shorties vs. Long Tube Headers #60209
05/20/08 11:23 AM
05/20/08 11:23 AM
a cornfield near you
BlakDak Offline OP
BlakDak  Offline OP
I currently have gibson shorties on my 93 Dakota..... the exhaust from the y back needs replaced.
I saw that hooker makes a full length header for 87 to 91 trucks. I assume they will fit the later till 96... I just can't run EGR.
Is there any benefit to this?
Re: Shorties vs. Long Tube Headers [Re: BlakDak] #60210
05/20/08 11:35 AM
05/20/08 11:35 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Long tube headers make more power than shorties, but how much more is a good question. I've heard some say shorties don't make much more power than manifolds. But I've never seen dyno runs on each type to confirm that. If your setup is not very serious, ie just a couple bolt-ons, you'd have to evaluate whether any possible power increase to you would be worth the price of a new set of headers.
You can lose EGR. Worst case scenario the computer stores a code saying something like 'no a/f ratio change detected when EGR solenoid activated'. Not exactly the end of the world there. But then, do you have emissions testing where you are? No EGR may cause a problem...
Re: Shorties vs. Long Tube Headers [Re: DaytonaTurbo] #60211
05/20/08 12:26 PM
05/20/08 12:26 PM
BlakDak Offline OP
BlakDak  Offline OP
no testing.... so not a problem, unless it kicks the light on, then it will annoy the chit out of me...:D
I'll probably be dropping a 5.9 in soon with a cam, 1.7 rockers, single plane intake, maybe some ally heads.
So I am kinda planning ahead.
They don't show pics of them, and I would be really po'd if they are nothing but regular truck headers.
Re: Shorties vs. Long Tube Headers [Re: BlakDak] #60212
05/20/08 11:26 PM
05/20/08 11:26 PM
BlakDak Offline OP
BlakDak  Offline OP
I was looking under the truck today.... it looks like it would be a pain to run exhaust with long tube headers.
Re: Shorties vs. Long Tube Headers [Re: BlakDak] #60213
05/21/08 12:11 AM
05/21/08 12:11 AM
Manitoba, Canada
Manitoba, Canada
Yeah, and in what vehicle is it not a pain?
Re: Shorties vs. Long Tube Headers [Re: DaytonaTurbo] #60214
05/21/08 06:29 AM
05/21/08 06:29 AM
Seattle, WA
3
375inStroke Online content
Special needs person
375inStroke  Online Content
3
Seattle, WA
Here's a smallblock exhaust shootout: Exhaust Blowout on a Mopar 300hp Crate
Re: Shorties vs. Long Tube Headers [Re: DaytonaTurbo] #60215
05/21/08 06:32 AM
05/21/08 06:32 AM
Mass
dgc333 Offline
dgc333  Offline
Mass
FWIW, here are some rules of thumb on headers.
1. tube diameter determines the rpm at which the torque peak occurs.
2. The length of the tube rocks the curve around the torque peak with longer tubes favoring rpms below the peak and shorter tubes above the peak.
3. Larger Collector diameter increases the torque above the peak, smaller below the peak.
4. longer collectors increase torque below the peak and shorter above.
In a nut shell shorty headers will be most beneficial in the higher rpm ranges and in the case of an otherwise stock engine the cam and intake are designed for low rpm torque so they have a modest benefit at best.
Dave Clement Pembroke, MA 03 PT Cruiser GT Turbo 99 Dakota SLT+ CC 4x4 68 Barracuda sport coupe http://home.comcast.net/~dgc333/
Re: Shorties vs. Long Tube Headers [Re: DaytonaTurbo] #60216
05/21/08 08:39 AM
05/21/08 08:39 AM
BlakDak Offline OP
BlakDak  Offline OP
the big thing is the gas tank...... if it wasn't there, it'd be a piece of cake...:P
Re: Shorties vs. Long Tube Headers [Re: BlakDak] #60217
05/21/08 09:22 AM
05/21/08 09:22 AM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
Two words: Fuel Cell
Plenty of room for one in the bed, and then you can run just about whatever exhaust you want...
Clair
Re: Shorties vs. Long Tube Headers [Re: Clair_Davis] #60218
05/21/08 01:27 PM
05/21/08 01:27 PM
BlakDak Offline OP
BlakDak  Offline OP
I still use it as a truck.....
I want it to haul, and haul [Edited by Moparts - Keep it clean]...:P
Re: Shorties vs. Long Tube Headers [Re: BlakDak] #60219
05/22/08 08:02 AM
05/22/08 08:02 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
We would be all better off
if we stuck to using the term
"Long Tube Header"
for a sb V8 as being a header with primary pipe
over 42 inches
like MP engineer Larry Shepard says works best
and the Dulcich 'blowout' article seems to confirm.
All the rest are
"Shorties"
including the Hooker
mentioned above
A good rough rule of thumb
is that shorty 4 into 1 headers
give no more than a 3% max hp boost
while the long tubes may be good for 5%
