Re: 500" Engine Build 440 Source?
[Re: kz5rt2]
#602132
02/02/10 10:45 PM
02/02/10 10:45 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
I forgot to mention, I'm looking at no more than a CR of 9.5:1.
Why so low? Aluminum heads pull enough heat out to typically allow an extra point of compression without worries of detonation... & if you get the right combonation of parts to have effective quench thats good for another half point... Lots of streetable engine run 10.5-10.8 on pump fuel...
[Re: kz5rt2]
#602137
02/02/10 11:14 PM
02/02/10 11:14 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Eventually I plan on installing a crossram setup. Didn't the max wedge/superstock manifolds flow well?
They flow as well as any manifold.. The just weigh a ton... But I think the cool factor is well worth it.. Unless your building a race car 500 inches means enough torque that you can leave a little on the table & still have an ear to ear grin...
[Re: kz5rt2]
#602138
02/02/10 11:29 PM
02/02/10 11:29 PM
Posts: 31,069 Oregon
AndyF
Look in the tech archives for plenty of 500 inch stroker builds. http://www.moparts.org/Tech/Archive/bigblock.htmlI also wrote an entire book on the subject which you can find at various Mopar parts dealers. I don't think you'll need the 3.91 gears if you build a 500 inch engine. 3.55 will work just fine as will 3.23 gears.
[Re: AndyF]
#602139
02/02/10 11:52 PM
02/02/10 11:52 PM
Posts: 3,031 Erda, UT
67Charger
Erda, UT
My 496" 440 source motor runs 10.4:1, .034" quench with the Eddie RPM heads and is faster on pump gas than on race fuel. The cam is .604"/.597", 264°/259° solid. I've spun it to 7000, and the timing is 18° initial and 34° total. After tuning it is putting out right at the 600HP mark and 600 ft.lbs from 3000 on.
11.33 @ 118.46 on motor 10.75 @ 125.35 w/ a little spray Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
[Re: ahy]
#602142
02/04/10 10:33 PM
02/04/10 10:33 PM
Posts: 1,954 Blairsden, CA
Triggerfish
Blairsden, CA
Quench means at least part of the piston comes very close to the head at TDC. The near contact stirs up the mixture to help cool it and prevent detonation. .040" clearnace is considered ideal and fairly easy to get with Ed or 440 Source heads. Set the flat part of the piston at zero deck (piston comes right up to the top of the block) and use a common .040" thick head gasket and you have it.
Careful piston choice, deck machining and/or custom pistons may be required to get 0 deck but the benefit is significant.
Very true & ceramic coatings for the combustion chambers & piston tops also can significantly prevent hot spots & detonation, so w/ quench, aluminum heads & coatings, you should have no problem w/ high compression.
[Re: kz5rt2]
#602143
02/04/10 10:34 PM
02/04/10 10:34 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
I think you are ok, (cannot remember how they route) but you may want to check to make sure the angle plug of the Edelbrocks will work with your manifolds. Otherwise the straight plug Stealth will have to do.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: cragar]
#602146
02/05/10 12:47 AM
02/05/10 12:47 AM
Posts: 7,497 Austin, TX
HemiDave
Austin, TX
so 915 with .040 quench what compression can I run and still use pump regular or premium?
About 9.5:1 with the steel heads.
[Re: HemiDave]
#602148
02/05/10 01:14 PM
02/05/10 01:14 PM
Posts: 121 Detroit, MI
kz5rt2
Detroit, MI
So. 10.5:1 is sufficient with the stealth heads and still run pump gas?
