Page 1 of 3 1 2 3
500" Engine Build 440 Source? #602130
02/02/10 10:29 PM
02/02/10 10:29 PM
Detroit, MI
kz5rt2 Offline OP
kz5rt2  Offline OP
Detroit, MI
I'm just beginning my first stroker build. I've built more or less stock 440's and have dyno'd around 450 hp basically a little more than stock setup.
I've searched around on the forums and 440source is bar none the biggest bang for the buck! During the last couple of weeks, I've traded a few emails with them asking about a complete parts list for the build along with dyno results if possible.
Here's what I plan to run it in.
Early B body stock Plymouth.
3:91
2500 stall
max wedge exhaust manifolds coupled to a full 3" exhaust
Edelbrock RPM performer intake
Edelbrock 800 carb.
Here's where I'm looking for guidance on the engine build.
-440 block .030
-4.350"
(.030 over) -24 (Dish) 1.867" -.018" P/N: 440.500.5080
Does anyone have knowledge on the stealth heads, or are the edelbrock's recommended?
Camshaft?????
Comp Cam Xtreme Energy Hi-Lift .564"
Any help or experience with 440source products is greatly appreciated! I rarely see anything negative about 440source!
Regards,
Re: 500" Engine Build 440 Source? [Re: kz5rt2] #602131
02/02/10 10:32 PM
02/02/10 10:32 PM
Detroit, MI
kz5rt2 Offline OP
kz5rt2  Offline OP
Detroit, MI
I forgot to mention, I'm looking at no more than a CR of 9.5:1.
Re: 500" Engine Build 440 Source? [Re: kz5rt2] #602132
02/02/10 10:45 PM
02/02/10 10:45 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Why so low? Aluminum heads pull enough heat out to typically allow an extra point of compression without worries of detonation... & if you get the right combonation of parts to have effective quench thats good for another half point... Lots of streetable engine run 10.5-10.8 on pump fuel...
Re: 500" Engine Build 440 Source? [Re: 1_WILD_RT] #602133
02/02/10 10:54 PM
02/02/10 10:54 PM
Detroit, MI
kz5rt2 Offline OP
kz5rt2  Offline OP
Detroit, MI
Yes, you're right, it would probably be a good idea to shave another .5 pt out of it. I'm jusr paranoid to ping and overheat problems.
Re: 500" Engine Build 440 Source? [Re: kz5rt2] #602134
02/02/10 10:56 PM
02/02/10 10:56 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I would still build for quench just use the large dish to lower the C/R... Quench is always beneficial...
Re: 500" Engine Build 440 Source? [Re: kz5rt2] #602135
02/02/10 10:59 PM
02/02/10 10:59 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Why build a big motor and choke it W/ manifolds?
Re: 500" Engine Build 440 Source? [Re: WILD BILL] #602136
02/02/10 11:02 PM
02/02/10 11:02 PM
Detroit, MI
kz5rt2 Offline OP
kz5rt2  Offline OP
Detroit, MI
Eventually I plan on installing a crossram setup. Didn't the max wedge/superstock manifolds flow well?
Re: 500" Engine Build 440 Source? [Re: kz5rt2] #602137
02/02/10 11:14 PM
02/02/10 11:14 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
They flow as well as any manifold.. The just weigh a ton... But I think the cool factor is well worth it.. Unless your building a race car 500 inches means enough torque that you can leave a little on the table & still have an ear to ear grin...
Re: 500" Engine Build 440 Source? [Re: kz5rt2] #602138
02/02/10 11:29 PM
02/02/10 11:29 PM
AndyF Online content
AndyF  Online Content
Look in the tech archives for plenty of 500 inch stroker builds.
http://www.moparts.org/Tech/Archive/bigblock.html
I also wrote an entire book on the subject which you can find at various Mopar parts dealers.
I don't think you'll need the 3.91 gears if you build a 500 inch engine. 3.55 will work just fine as will 3.23 gears.
Re: 500" Engine Build 440 Source? [Re: AndyF] #602139
02/02/10 11:52 PM
02/02/10 11:52 PM
Erda, UT
67Charger Offline
67Charger  Offline
Erda, UT
My 496" 440 source motor runs 10.4:1, .034" quench with the Eddie RPM heads and is faster on pump gas than on race fuel. The cam is .604"/.597", 264°/259° solid. I've spun it to 7000, and the timing is 18° initial and 34° total. After tuning it is putting out right at the 600HP mark and 600 ft.lbs from 3000 on.
11.33 @ 118.46 on motor
10.75 @ 125.35 w/ a little spray
Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race
Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
Re: 500" Engine Build 440 Source? [Re: 67Charger] #602140
02/04/10 09:56 PM
02/04/10 09:56 PM
Detroit, MI
kz5rt2 Offline OP
kz5rt2  Offline OP
Detroit, MI
Excuse my ignorance, but what does it mean when you guys use the terminology "quench"?
I am leaning toward eddie's heads, but the price of 440source's stealth heads are very attractive. Has anybody had/know of someone with experience using those heads.
Re: 500" Engine Build 440 Source? [Re: kz5rt2] #602141
02/04/10 10:25 PM
02/04/10 10:25 PM
IN
ahy Offline
ahy  Offline
IN
Quench means at least part of the piston comes very close to the head at TDC. The near contact stirs up the mixture to help cool it and prevent detonation. .040" clearnace is considered ideal and fairly easy to get with Ed or 440 Source heads. Set the flat part of the piston at zero deck (piston comes right up to the top of the block) and use a common .040" thick head gasket and you have it.
Careful piston choice, deck machining and/or custom pistons may be required to get 0 deck but the benefit is significant.
Re: 500" Engine Build 440 Source? [Re: ahy] #602142
02/04/10 10:33 PM
02/04/10 10:33 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
Very true & ceramic coatings for the combustion chambers & piston tops also can significantly prevent hot spots & detonation, so w/ quench, aluminum heads & coatings, you should have no problem w/ high compression.
Re: 500" Engine Build 440 Source? [Re: kz5rt2] #602143
02/04/10 10:34 PM
02/04/10 10:34 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
I think you are ok, (cannot remember how they route) but you may want to check to make sure the angle plug of the Edelbrocks will work with your manifolds. Otherwise the straight plug Stealth will have to do.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: 500" Engine Build 440 Source? [Re: kz5rt2] #602144
02/05/10 12:12 AM
02/05/10 12:12 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The 500" stroker will be choking if you use the stock Stealth heads. You'd need to go with their CNC'd heads or step up to something else with the same or better flow.
A zero decked block with a closed chamber head and .040 gasket will provide the quench. What you need to figure out is which of their pistons will give you your desired CR with the above.
I have a 440Source kit (528") and I'm pleased with what I see HOWEVER, it is not a "drop in" assembly. So far I've noticed that the pins don't fit in the rods and the rods will need to be honed. It looks like the damper (theirs) isn't going to fit the crank either.
Re: 500" Engine Build 440 Source? [Re: Stanton] #602145
02/05/10 12:19 AM
02/05/10 12:19 AM
mission /ashcroft raceways b.c...
cragar Offline
cragar  Offline
so 915 with .040 quench what compression can I run and still use pump regular or premium?
Re: 500" Engine Build 440 Source? [Re: cragar] #602146
02/05/10 12:47 AM
02/05/10 12:47 AM
Austin, TX
HemiDave Offline
HemiDave  Offline
Austin, TX
About 9.5:1 with the steel heads.
Re: 500" Engine Build 440 Source? [Re: HemiDave] #602147
02/05/10 12:57 AM
02/05/10 12:57 AM
Austin, TX
HemiDave Offline
HemiDave  Offline
Austin, TX
Yep, run the items you listed, get the pistons for 0 deck (10.5:1 compr ratio), get the Stealth heads (they will be fine on the street), paint 'em same as the block and tell everyone it's a 440 with just an aftermarket intake...
Re: 500" Engine Build 440 Source? [Re: HemiDave] #602148
02/05/10 01:14 PM
02/05/10 01:14 PM
Detroit, MI
kz5rt2 Offline OP
kz5rt2  Offline OP
Detroit, MI
So. 10.5:1 is sufficient with the stealth heads and still run pump gas?
Re: 500" Engine Build 440 Source? [Re: kz5rt2] #602149
02/05/10 02:19 PM
02/05/10 02:19 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Yes because the aluminum pulls heat out of the chamber area much quicker than iron.. And depending on the fuel you have available somr guys run over 11-1 on pump fuel... I'm building mine at a true 10.25 cause I'd rather be conservative & know it will be safe with Californias lousy fuel & still make all the power I need for a street toy..
Page 1 of 3 1 2 3
