Valve cover baffles. #60127
05/20/08 09:56 AM
05/20/08 09:56 AM
Snowing in the north!
Dart 340 Offline OP
moparts member
Dart 340  Offline OP
moparts member
Is it a good idea to also install a baffle on the
breather side of the valve covers? Obviously the
PCV side will suck oil, but the breather side is almost always a draw in correct?
Re: Valve cover baffles. [Re: Dart 340] #60128
05/20/08 10:04 AM
05/20/08 10:04 AM
Eastern North Carolina
cyphre666 Offline
cyphre666  Offline
If you have them and have the clearence, go ahead and use them. Keeps oil from slashing up onto
breather when driving and stopping.
Keeps the breather cleaner.
Re: Valve cover baffles. [Re: cyphre666] #60129
05/20/08 11:47 AM
05/20/08 11:47 AM
God's Country Maryland
GODSCOUNTRY340 Offline
The breather is only a draw at idle and light throttle. When you're really accelerating the PCV valve is now useless, no vacuum to operate it. Now the breather is venting the blow-by. Make sure there are baffles on both or you'll quickly oil soak the breather making it less effective, ugly and an oil dripper on your engine.
