Hemi ballancer and pulleys? #601216
02/01/10 09:45 PM
02/01/10 09:45 PM
central P.A.
HEMIDOG 70 Offline OP
central P.A.
I am ready to purchase the front end components for my 528 Hemi project do I have to use the thick hemi damper? I am useing a K-1 4.150 stroke crank stock size K-1 rods and 4.500 Diamond pistons. Could I use the thinner 440 style damper and pulleys, that way I don't have to buy the Hemi pulleys.Will it line up?
Re: Hemi ballancer and pulleys? [Re: HEMIDOG 70] #601217
02/01/10 10:44 PM
02/01/10 10:44 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Crate motors use the thin balancer, and I dont belive there is a thick balancer that is SFI approved..
The factory 440 pulleys should work with thin balancer.
Re: Hemi ballancer and pulleys? [Re: sthemi] #601218
02/02/10 01:58 PM
02/02/10 01:58 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
MP sells a Thick SFI balancer BUT it has a recessed face , you would use the WEDGE pulleys with it .
But yes you can use a thin balancer if you want , as stated the crate motors come that way now .
Re: Hemi ballancer and pulleys? [Re: JohnRR] #601219
02/02/10 08:26 PM
02/02/10 08:26 PM
central P.A.
central P.A.
Thanks guys that was the info I needed. Looks like I can save a couple $$ on the pulleys anyway.
