Re: 440 engine identification
[Re: roy2345]
#600460
02/01/10 10:13 AM
02/01/10 10:13 AM
Posts: 447 Knoxville, TN
YGBSM
Knoxville, TN
2536430 - 8 right?
2536430 is the number for a 440
8 just means that the tooling has been reconditioned eight times
1968 Charger R/T 2015 Charger R/T Scat Pack 2017 Durango Citadel
[Re: roy2345]
#600462
02/01/10 12:37 PM
02/01/10 12:37 PM
RapidRobert
look at the machined pad up top sorta by the dist & give us the hand stamped #'s and letters on it. The prefix # will tell you the year and the pad will also have the CID either 383 or 440. either way you have 906 heads.
[Re: Mopar Grandpa]
#600464
02/01/10 02:21 PM
02/01/10 02:21 PM
Posts: 2,636 Nashville, TN
MOPARMIKE69
Nashville, TN
Yes they do it is just in a different place than the 440. That is for the assembly date for the block. The partial Vin stamping is still the same place of both 383 and 440.
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
[Re: roy2345]
#600477
02/04/10 12:38 PM
02/04/10 12:38 PM
YGBSM
Knoxville, TN
1970 block assembled June 22, 1970.
