440 engine identification #600458
02/01/10 09:20 AM
02/01/10 09:20 AM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
I pulled this engine out of a 70 Chrysler New Yorker. The numbers I saw on the block are 25364308..What do I have based on these numbers? Heads etc.?
Re: 440 engine identification [Re: roy2345] #600459
02/01/10 09:57 AM
02/01/10 09:57 AM
eganville ont
440beep Offline
440beep  Offline
eganville ont
that number is
2536430 440 1966-72 RB
2899830 383 1970 B
2568130 383 1959-71 B
Casting Number on LH Side of Engine VIN Number Stamped on RH Engine Pad
Casting Number CID Year Type Remarks
2202843 170 1960-64 G
2463230 170 1965 G
2463395 170 - G
2264478 170 - G
2205630 170 - G
2463430 225 1966 RG
2806830 225 1968-70 RG Includes 198
3462605 225 1975 RG
2951694 225 - RG
2202857 225 - RG
2205528 225 - RG
2465330 273 1964-66 LA
2806030 273 1966-69 LA
2463252 273 - LA
2536130 273 1965-69 LA
2806130 273 1966-69 LA
2264230 318 1960-66 A Polysphere
2468230 318 - A Polysphere
2532630 318 - A Polysphere
2466090 318 1967-74 LA
2806030 318 1966-69 LA
2806030 318 1967-74 LA
2536030 318 1967-75 LA
2566080 318 - LA
4104230 318 - LA Race - Painted Orange
2780930 340 1968-73 LA Except T/A & AAR
3577130TA 340 - 6 bbl 1970 LA T/A & AAR
1944929 350 1958
3418496 360 1971-74 LA
3870230 360 1975-78 LA
4179930 360 1975-1993 LA
1737629 361 1961-64 B
2120329 361 1958-66 B
2120429 361 - B
2128854 361 1964 B
2205712 361 1958-66 B
1945429 361 1965 B
2658930 361 1965 B
2120229 361 - B Industrial
1852029 413 1959-62 RB Max Perf. & Truck
2120529 413 1959-65 RB
2205697 413 1959-65 RB Passenger Car
2468030 413 - RB
2658836 413 - RB Industrial
2205697 426 1964 RB Passenger Car
2406730 426 1963-65 RB Wedge & Max Perf.
1852029 426 1962-65 RB Wedge
2468030 426 - RB Wedge
2440873 426 - RB Wedge
2532230 426 1964-66 RB Wedge & Max Perf.
2658836 426 - RB Industrial
1851729 383 1959-64 B
2128854 383 1964 B
2532130 383 1965 B
2120329 383 1959-60 RB Golden Lion
2899830 383 1970 B
2468330 426 1964-71 RB Hemi Head
3614230 400 1971-72 B
3698630 400 1973-78 B
4006530 400 1976-78 B
3698830 440 1973-78 RB
4006630 440 1978 RB
Plymouth's gonna getcha! There are 3 things that will live forever, cockroaches, Keith Richards, & slant 6 Dusters 71 gtx 440 4speed air grabber blue on blue with white vinyl roof
Re: 440 engine identification [Re: roy2345] #600460
02/01/10 10:13 AM
02/01/10 10:13 AM
Knoxville, TN
Y
YGBSM Offline
YGBSM  Offline
Y
Knoxville, TN
2536430 - 8 right?
2536430 is the number for a 440
8 just means that the tooling has been reconditioned eight times
1968 Charger R/T
2015 Charger R/T Scat Pack
2017 Durango Citadel
Re: 440 engine identification [Re: YGBSM] #600461
02/01/10 11:33 AM
02/01/10 11:33 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
All 2536 430 8 tells you is that it was built tween 68 - 72.
Need more numbers to narrow it down.
Re: 440 engine identification [Re: roy2345] #600462
02/01/10 12:37 PM
02/01/10 12:37 PM
look at the machined pad up top sorta by the dist & give us the hand stamped #'s and letters on it. The prefix # will tell you the year and the pad will also have the CID either 383 or 440. either way you have 906 heads.
Re: 440 engine identification [Re: RapidRobert] #600463
02/01/10 02:09 PM
02/01/10 02:09 PM
Sebring, Florida
Mopar Grandpa Offline
Sebring, Florida
383's didn't have the machined pad.
Re: 440 engine identification [Re: Mopar Grandpa] #600464
02/01/10 02:21 PM
02/01/10 02:21 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Yes they do it is just in a different place than the 440. That is for the assembly date for the block. The partial Vin stamping is still the same place of both 383 and 440.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: 440 engine identification [Re: MOPARMIKE69] #600465
02/01/10 07:24 PM
02/01/10 07:24 PM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
ok....when the engine was out a few months ago I recall the casting date was 1970. I saw that. but it's hard to see that side of the block now vs the other side. But I know it's a casting year of 1970. So does this help? But I should have the 906 Heads?
Re: 440 engine identification [Re: roy2345] #600466
02/01/10 07:28 PM
02/01/10 07:28 PM
but it's hard to see that side of the block now vs the other side. But I should have the 906 Heads?
(1) forget that & check the machined pad up on top (2) yes 906's
Re: 440 engine identification [Re: RapidRobert] #600467
02/02/10 02:30 AM
02/02/10 02:30 AM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
so if I put a Cam in there then I have a HP factory spec engine basically?
Re: 440 engine identification [Re: roy2345] #600468
02/02/10 01:50 PM
02/02/10 01:50 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Sort of , the HP engine had different rods and double springs on the heads and a few other tidbits ... that's assuming it's a 70 or 71 model year engine , the casting date only tells you when the block was cast , noit when and what it was actually built ... assuming it's the original engine from the car you got it from ...
Re: 440 engine identification [Re: JohnRR] #600469
02/02/10 04:43 PM
02/02/10 04:43 PM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
double springs on the heads? Can anyone xplain that 2 me?
Re: 440 engine identification [Re: roy2345] #600470
02/02/10 06:12 PM
02/02/10 06:12 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I doubt if they are true double springs. Probably a single spring with a damper.
Re: 440 engine identification [Re: 6PakBee] #600471
02/03/10 11:46 AM
02/03/10 11:46 AM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
anyone have pics of some heads with double springs?
Re: 440 engine identification [Re: roy2345] #600472
02/03/10 12:13 PM
02/03/10 12:13 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
One smaller diameter spring goes inside the other.
Re: 440 engine identification [Re: roy2345] #600473
02/03/10 01:03 PM
02/03/10 01:03 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
easier than that... find this pad and will get the displacement on a stamped number.
Re: 440 engine identification [Re: Mopar Grandpa] #600474
02/03/10 01:07 PM
02/03/10 01:07 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
pad for BBs are in here:
the other location is on RBs
Re: 440 engine identification [Re: JohnRR] #600475
02/03/10 01:09 PM
02/03/10 01:09 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I think they were springs with dampener, not double really
Re: 440 engine identification [Re: NachoRT74] #600476
02/04/10 12:02 PM
02/04/10 12:02 PM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
ok the numbers on the pad on the block is F 440 then the other numbers are 6 22......what do I have?
Re: 440 engine identification [Re: roy2345] #600477
02/04/10 12:38 PM
02/04/10 12:38 PM
Knoxville, TN
Y
YGBSM Offline
YGBSM  Offline
Y
Knoxville, TN
1970 block assembled June 22, 1970.
1968 Charger R/T
