BB throttle cable brackets #59986
05/19/08 10:24 PM
05/19/08 10:24 PM
St. Charles, MO
wingman Offline OP
Uncreative Title
wingman  Offline OP
Uncreative Title
St. Charles, MO
Are they all the same?
Put the bracket from my 383 on my new 440 and it is not even close to lining up. Looked in some aftermarket catalogs and they all list the same part #.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: BB throttle cable brackets [Re: wingman] #59987
05/19/08 10:38 PM
05/19/08 10:38 PM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
Your bracket is bent. The clamp that holds the throttle cable should be horizontal. Just bend it back to line up.
Ron
Re: BB throttle cable brackets [Re: Ronnman] #59988
05/19/08 10:51 PM
05/19/08 10:51 PM
St. Charles, MO
wingman Offline OP
Uncreative Title
wingman  Offline OP
Uncreative Title
St. Charles, MO
Mmmm. Could be, but I don't think so. Kickdown linkage pivot looks straight up and down.
"Finger" on bracket prevents it from being bent any futher down, and if I bend it up it will just make it worse.
Is there an "RB" bracket?
Re: BB throttle cable brackets [Re: wingman] #59989
05/19/08 11:11 PM
05/19/08 11:11 PM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
I can see better in the 2nd pic. You also need a bracket that screws on the the Demon throttle plate. I just used one for a Holley and had to open up one of the holes. Is the intake higher than the stock manifold?
Ron
Re: BB throttle cable brackets [Re: Ronnman] #59990
05/19/08 11:17 PM
05/19/08 11:17 PM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
Another option would be to buy a bracket for a high rise manifold. One on ebay http://cgi.ebay.com/ebaymotors/Mopar-Cus...sspagenameZWDVW
Re: BB throttle cable brackets [Re: wingman] #59991
05/20/08 12:37 AM
05/20/08 12:37 AM
AndyF Offline
AndyF  Offline
383 uses a different throttle bracket than a 440. The 440 block is about 3/4 of an inch taller so the intake manifold is wider.
Re: BB throttle cable brackets [Re: AndyF] #59992
05/20/08 02:15 AM
05/20/08 02:15 AM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
this man knows what he's talking about, he makes the bracket shown in the ebay ad...
Re: BB throttle cable brackets [Re: CokeBottleKid] #59993
05/20/08 02:49 AM
05/20/08 02:49 AM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
I've had one for a few years and it flat out rules. Nothing else ever needed.
Ride eternal, shiny and chrome
Re: BB throttle cable brackets [Re: AndyF] #59994
05/22/08 11:53 PM
05/22/08 11:53 PM
IN
polaraholic Offline
polaraholic  Offline
IN
Will the bracket shown in the above post work on any year 440. I need one to put on a 440 going into a 74 challenger? Steve
