Re: SB Procomp roller rocker for stroker motor ?
[Re: AndyF]
#599767
01/31/10 06:53 PM
01/31/10 06:53 PM
Posts: 892 USA
krw71ragtop
USA
I don't know anything about ProComp but you might take a look at the PRW rocker arms for small block Mopar engines. They look pretty good and come in a couple of different ratios.
I was checking out the for sale Sb engine section and found an Ad for the Procomps 1.5 or 1.6's by member B&G Service. Just wondering if anyone here has used these rockers. They're priced reasonable. I sent them a PM just waiting for an answer.
[Re: BradH]
#599769
01/31/10 08:34 PM
01/31/10 08:34 PM
Posts: 892 USA
krw71ragtop
USA
All those "Shanghai Sharp" brands of rockers scare the pee outta me. Some of them actually look really nice, but I simply don't want to be the guinea pig if they drop roller tips or needles somewhere down the road.
I have a set of Indy roller rockers on my 416" but only have 288 street miles on the motor, then pulled it for the dyno. So they really havent been tested ! Looking for something that will hold up to around 500 hp in my 410" .
[Re: krw71ragtop]
#599770
01/31/10 08:56 PM
01/31/10 08:56 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
I used a set of the Procomp 1.5 aluminum rockers for two season on a 340 for bracket racing. Had no problems with them...removed them only because i wanted to use 1.6 ...
these had the roller bearing..
cam was a mopar .557 with mopar spring P3412068
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: AndyF]
#599772
01/31/10 09:59 PM
01/31/10 09:59 PM
Posts: 660 San Diego
formula S
San Diego
I used some on an 360 and it took 3 sets to get the right spacers and rocker hold downs, also IMO they dont control oil very well, the rockers have two narrow bushings one in each side of the rocker creating a channel in the middle alowing oil to constantly escape you should heve seen the rockers when I primed the engine it looked liked a lawn sprinkler. I built this 360 in sept of 08 and it is still running fine but if I do it again I'll probably use something else, it was to much hassle.
[Re: Ian]
#599774
01/31/10 10:29 PM
01/31/10 10:29 PM
Posts: 8,547 State College, PA
RyanJ
moparts member
moparts member
State College, PA
I've only used one set of Pro Comps.... mostly because I do more high $ motors than budget ones, but they were on off shelf Comp Hyd. Flat tappet, 120 seat pressure, 300 open.... for daily driver truck engine..... put 6000 miles on them on set of Edelbrocks, no issues. Motor is still running in board member's Cuda in Maine to this day.... It was funny, the one rocker adjuster came out of box with the allen key hex missing from the top of the adjuster. Made for fun time setting pre-load on lifter.
I have set of the PRW Chrome moly rockers on my driver 448 big block, so far 3000+ miles on a solid roller, & the bushings look like new. I did run a hone through them to increase clearance/put some cross hatch on them when new & the adjusters they came with were beyond brittle, they broke while tightening lock nut adjusting lash for first time. Replaced them with T&D adjusters/nuts & no problems.... The PRW Aluminum stuff looks just like old Aluminum/large diameter needle bearing CATs. Not something I would want to use..... the Pro Comp's do not have needle bearings on shaft.... they are just a bored aluminum rocker body, riding on a Pioneer $18 shaft.
[Re: RyanJ]
#599775
01/31/10 11:43 PM
01/31/10 11:43 PM
Posts: 892 USA
krw71ragtop
USA
Thanks for the discription Ryan Sounds like they're alot different than the Indy's.
[Re: 70AARcuda]
#599776
01/31/10 11:49 PM
01/31/10 11:49 PM
Posts: 892 USA
krw71ragtop
USA
Did you replace the 1.5's with Procomp 1.6's ? If so any issues ?
