Detroit Area - Who Can re-Curve a Distributor? #59965
05/19/08 10:04 PM
05/19/08 10:04 PM
Addison Twp, Mi.
RobG Offline OP
RobG  Offline OP
Addison Twp, Mi.
There was a shop in the 22 or 23 mile and Van Dyke area - are there any other shops in the area?
I am not rich...but I get off my ass everyday to make sure I am not broke!
Can we get the Mexican cartels to help us with our supply chain issues? They don't seem to have any trouble getting stuff from one place to another.
Re: Detroit Area - Who Can re-Curve a Distributor? [Re: RobG] #59966
05/19/08 10:35 PM
05/19/08 10:35 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
its not hard to do it yourself. i would start there. for a small block your want about 36° total timing in the plate. you need to weld up or braze the slots on the distributor closed a little until you get to the right setting. there is a number stamped into the plate. the number is the degrees advanced at the crank, so double that and you get your advance in the plate. measure the slot and then you do a little math... slot length*desired advance divided by plate number times 2. that will give you the new slot length. so a little brazing and some filing and you'll be good to go.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Detroit Area - Who Can re-Curve a Distributor? [Re: RobG] #59967
05/19/08 10:35 PM
05/19/08 10:35 PM
dead center
CHRONiklyDEMONic Offline
Demonized
Demonized
dead center
You!!
"After a Day filled with burning Rubber, you may find it time to re-tire."
Re: Detroit Area - Who Can re-Curve a Distributor? [Re: CHRONiklyDEMONic] #59968
05/20/08 08:10 AM
05/20/08 08:10 AM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
I can do that service for you. We are located 3 blocks south of m59 off van dyke. I can be reached on my cell 586 924 0012 or the shop 7266900. Thanks Jake
JAKES AUTOMOTIVE
Re: Detroit Area - Who Can re-Curve a Distributor? [Re: JAKE68] #59969
05/20/08 08:40 AM
05/20/08 08:40 AM
Addison Twp, Mi.
RobG Offline OP
RobG  Offline OP
Addison Twp, Mi.
Great - I'll give you a call!
