Page 6 of 9 1 2 3 4 5 6 7 8 9
Re: 2009 Mopar Nationals Pink T/A build [Re: JulesdaWiperman] #599338
02/14/10 12:54 PM
02/14/10 12:54 PM
Mass
Mike Mancini Offline
Mass
Happy Valentine's Day Mike Ross!
Michael L. Mancini
American Muscle Car Restorations, Inc.
65 Foliage Drive
N. Kingstown, RI
Premium Quality Restoration Services for Hi-Performance & Classic Automobiles. OE Specialists.
Instrument Specialties, Inc
www.instrument-specialties.com
www.manciniresto.com
www.performancecargraphics.com
Re: 2009 Mopar Nationals Pink T/A build [Re: Mike Mancini] #599339
02/14/10 01:11 PM
02/14/10 01:11 PM
Georgetown Ontario Canada
anlauto Offline
anlauto  Offline
Michael, that dash looks great !
How do you re-do the chrome "circles" around the gauges?
CHECK OUT MY NEW WEB SITE !
Re: 2009 Mopar Nationals Pink T/A build [Re: HEMICUDA] #599340
02/16/10 09:01 PM
02/16/10 09:01 PM
western PA
mopar4ya Offline
mopar4ya  Offline
western PA
No, the drive shaft isn't painted.
So who and how was the drive shaft done. It looks great! as does the rest of the car.
Dan.
Re: 2009 Mopar Nationals Pink T/A build [Re: mopar4ya] #599341
02/16/10 10:20 PM
02/16/10 10:20 PM
Land of 10,000 Lakes
44D6PAKCUDA Offline
44D6PAKCUDA  Offline
Maybe Dave W and/or Mike can chime in to let us know how the process to make the driveshaft look so good.I know many hours,but what steps,materials,grades of sandpaper,etc is used.Last time I looked outside I still see 24+ of snow to melt so I got time...
Re: 2009 Mopar Nationals Pink T/A build [Re: 44D6PAKCUDA] #599342
02/18/10 07:40 AM
02/18/10 07:40 AM
grand rapids mi. usa
P
Purestocker Offline
Purestocker  Offline
P
It all depends on the original condition of your drive shaft, The drive shaft in the tube trick works great if the drive shaft is not pitted real bad, if it is pitted you need to sand and polish working your way down to fine paper. but the part numbers on drive shafts are very shallow and go away quick, I use the Evapo rust (about 1 1/2 gallons (Harber freight) has it, put the drive shaft in a 6' piece of 4" pvc pipe capped on one end, let the drive shaft soak for 24 hrs. remove it and was it off real well, then I use steel wool to polish it, take the torch and heat all of the welds to re-blue them, paint the cast ends with cast spray, take a file to the original grinding marks on the yokes, install some DETROIT u-joints and your there, seal the whole shaft with plasti cote, and wipe it down with very fine wool to take the shine off after it is dry, originally these drive shafts looked like new steel exhaust pipe, it is very hard to replocate this look if the shaft is rusty to start with, hope this helps you. Rich
Re: 2009 Mopar Nationals Pink T/A build [Re: Purestocker] #599343
02/18/10 07:41 AM
02/18/10 07:41 AM
P
Purestocker Offline
Purestocker  Offline
P
PT #
Re: 2009 Mopar Nationals Pink T/A build [Re: Purestocker] #599344
02/18/10 07:45 AM
02/18/10 07:45 AM
P
Purestocker Offline
Purestocker  Offline
P
u-joint, These can be hard to find
Re: 2009 Mopar Nationals Pink T/A build [Re: HEMICUDA] #599345
02/23/10 11:52 AM
02/23/10 11:52 AM
Ont, Canada
moparo Offline
moparo  Offline
Ont, Canada
Mike
You might want to check the drive shaft it look to be backwards?? I see the taper end with the slip yoke on that side.
performancecarrestorations.com
Re: 2009 Mopar Nationals Pink T/A build [Re: moparo] #599346
02/23/10 10:58 PM
02/23/10 10:58 PM
anlauto Offline
anlauto  Offline
Mike
Yep...I'm with Mauro on that one..If it's an E Body driveshaft and only has one tapered end it would be and the back of the car, NOT the front
Re: 2009 Mopar Nationals Pink T/A build [Re: anlauto] #599347
03/05/10 03:01 AM
03/05/10 03:01 AM
West Coast, CA
Troy Offline
Troy  Offline
West Coast, CA
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
Re: 2009 Mopar Nationals Pink T/A build [Re: Troy] #599348
03/05/10 02:56 PM
03/05/10 02:56 PM
30 Rock
JS29 Offline
JS29  Offline
30 Rock
Yeah Mike, it is a nice sunny day. Roll that sucker outside and let's see some more pics. Should be sunny tomorrow too!
Re: 2009 Mopar Nationals Pink T/A build [Re: JS29] #599349
03/06/10 11:13 AM
03/06/10 11:13 AM
Medina, Ohio
HEMICUDA Offline OP
HEMICUDA  Offline OP
Medina, Ohio
Now for the special thx section of this post. Up first we have:
Mr. Dave Walden - ECS Automotive.
1. Complete sticker kit w/door vin sticker.
2. Dash tag transfer.
3. Front & rear date coded glass.
4. NOS dated coded fuel filter w/hoses.
5. NOS date coded voltage regulator.
6. Carb stickers.
7. Carpeting.
Jules - The Wiperman
1. Restored heater box supplied to him by my good friend Jim Miner.
2. Wiper motor.
Jimmy Ridge - Dixie
1. Alternator.
2. Starter.
David Tays (Plumbeeper)
Restored steering wheel - Compared to my survivor, his work is as close to original that you'll find on the planet.
Dales Cuda Shop
1. Complete exhaust system - Absolutely no drama installing, very nice piece.
2. Correct Challenger outside door handles.
3. Antenna.
Mike Mancini - Instrument Specialties
Complete gauge and bezel restoration, simply beautiful.
Wayne Brewer - Brewers Performance
All 4-speed parts including the column lockout linkage. Can't say enough good things about Wayne.
Frank Battleson
Dated coded hoses.
Bob Groser - Fine Lines
1. Brake/fuel lines.
2. Emergency brake cables.
3. Reinstalled prop. valve brackets.
4. Small rubber boot on the prop. valve.
Matt - MCB
1. Restored grille.
B/E & A Restoration Parts, Inc.
All the parts supplied by this low rent company were NOS pieces right off their shelve.
1. Side marker lenses and bezels.
2. Tail light lenses and bezels.
3. Front parking light lenses.
4. Inside door handles.
5. Inside lock levers.
6. Cowl screens.
7. Chrome radio knobs.
8. Drivers side mirror.
9. 3 piece tail trim.
Excluding the last one, anyone of these companies are in my "Good Guys and Buddy Club". It's a real pleasure dealing with quality people with good product, it sure makes putting together one of these heaps much easier.
Re: 2009 Mopar Nationals Pink T/A build [Re: HEMICUDA] #599350
03/06/10 11:15 AM
03/06/10 11:15 AM
Medina, Ohio
HEMICUDA Offline OP
HEMICUDA  Offline OP
Medina, Ohio
Dave Walden - Ecs Automotive
Re: 2009 Mopar Nationals Pink T/A build [Re: HEMICUDA] #599351
03/06/10 11:16 AM
03/06/10 11:16 AM
Medina, Ohio
HEMICUDA Offline OP
HEMICUDA  Offline OP
Medina, Ohio
Dave Walden - Ecs Automotive.
Re: 2009 Mopar Nationals Pink T/A build [Re: HEMICUDA] #599352
03/06/10 11:17 AM
03/06/10 11:17 AM
Medina, Ohio
HEMICUDA Offline OP
HEMICUDA  Offline OP
Medina, Ohio
Dave Walden - Ecs Automotive..
Re: 2009 Mopar Nationals Pink T/A build [Re: HEMICUDA] #599353
03/06/10 11:18 AM
03/06/10 11:18 AM
Medina, Ohio
HEMICUDA Offline OP
HEMICUDA  Offline OP
Medina, Ohio
Jules
Re: 2009 Mopar Nationals Pink T/A build [Re: HEMICUDA] #599354
03/06/10 11:19 AM
03/06/10 11:19 AM
Medina, Ohio
HEMICUDA Offline OP
HEMICUDA  Offline OP
Medina, Ohio
Jules.
Re: 2009 Mopar Nationals Pink T/A build [Re: HEMICUDA] #599355
03/06/10 11:20 AM
03/06/10 11:20 AM
Medina, Ohio
HEMICUDA Offline OP
HEMICUDA  Offline OP
Medina, Ohio
Jules..
Re: 2009 Mopar Nationals Pink T/A build [Re: HEMICUDA] #599356
03/06/10 11:21 AM
03/06/10 11:21 AM
Medina, Ohio
HEMICUDA Offline OP
HEMICUDA  Offline OP
Medina, Ohio
Jimmy Ridge - Dixie
Re: 2009 Mopar Nationals Pink T/A build [Re: HEMICUDA] #599357
03/06/10 11:22 AM
03/06/10 11:22 AM
Medina, Ohio
HEMICUDA Offline OP
HEMICUDA  Offline OP
Medina, Ohio
Jimmy Ridge - Dixie.
