Re: Stock Rockers - LA Small Block
[Re: BigDawg72]
#598726
01/30/10 11:18 PM
01/30/10 11:18 PM
Posts: 2,111 Bowie, MD
Reggie
Bowie, MD
Yeah, they should be oriented L-R in pairs over each cylinder.
[Re: BigDawg72]
#598727
01/30/10 11:22 PM
01/30/10 11:22 PM
RapidRobert
get the timing marks @ TDC & either the #1 or the #6 pair of rockers arms will be free. which plug wire the rotor is then pointing to will tell you which one. Hand turn the eng w a 1&1/4" socker/breaker bar 1/4 turn on the dampener or until the rotor moves to the next dist cap terminal (45 degrees) and the next cylinders' pair of rocker arms in the firing order will be free depending on if you started w #1 or #6. 1-8-4-3-6-5-7-2
[Re: RapidRobert]
#598728
01/31/10 12:26 AM
01/31/10 12:26 AM
RapidRobert
reggie, I have a pic in a Taylor/Hofer HP books manual showing the round dimples on stock production hyd rocker arms offset closer to each other but you have an actual photo of them offset to the outside. I'm confused
[Re: MoparforLife]
#598730
01/31/10 01:23 AM
01/31/10 01:23 AM
RapidRobert
Alright. Here's the pic I was speaking of & it appears in the mag to be an actual photo. EDIT I found another pic in the book of the same rockers and they ARE offset to the outside. I'm confused on how they accomplished that but now I know how they are supposed to go. Thanks Moparforlife.
[Re: RapidRobert]
#598731
01/31/10 03:14 AM
01/31/10 03:14 AM
Reggie
Bowie, MD
Yeah, I have that book too. It looks like someone mocked up the assembly in the photo up wrong.
[Re: BigDawg72]
#598736
01/31/10 02:07 PM
01/31/10 02:07 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
remember that you have to have the notches on the end of the rocker shaft down and forward on the left head and down and to the rear on the right side or you will not have oil to the top of the head.
Clean it, if it's Dirty. Oil it, if it Squeaks.
But: Don't fix it, if it Works!
[Re: MoparforLife]
#598737
01/31/10 06:28 PM
01/31/10 06:28 PM
Posts: 589 Waynesboro, PA
cuda_tim
Waynesboro, PA
When you say "on the left head" you mean Driver's side, correct?
[Re: MoparforLife]
#598739
01/31/10 07:51 PM
01/31/10 07:51 PM
Reggie
Bowie, MD
A lot of the rockers are also stamped with a L or R.
Yep. The ones in the pic that I posted are from a 308 head, and they are stamped with L and R, but you can't see it for the goo...
