RACER BROWN CAM SPEC'S #598646
01/30/10 06:20 PM
01/30/10 06:20 PM
Wi.
old_racer Offline OP
Wi.
got some parts from a guy's basement and there was a hemi cam racer brown stx-21.Looks like it was never used. I looked thru all my old mopar catalogs back into the 70's and can't find spec's for this cam, I know the stx's were solids, I put it in a block and the lobe lift is .370in and .368 exh, which is .580in and.560 exh with the standard hemi rocker ratio. Anyone got any old racer brown spec's around to look up the rest of the info, duration and lobe sep. lash etc?
thanks
Russ
Re: RACER BROWN CAM SPEC'S [Re: old_racer] #598647
01/30/10 06:26 PM
01/30/10 06:26 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
How's this.
