03 Neon Auto Trans #598267
01/30/10 01:00 PM
01/30/10 01:00 PM
Byesville, Ohio
Tomsecks Offline OP
Tomsecks  Offline OP
Byesville, Ohio
Anybody have one go south? Took a friends car to do the brakes, trans went out. Was going along w/ the cruise @ 75, car like shifts down to 3rd, I let off thinking it'll shift up into OD once there's no load, it doesn't. Slow down to about 55 and try to drive to the next exit, it just completely goes out, no gears work at all. Fluid level is good, nothing leaking, thoughts??? Dealer said 4k to do the repair!
Re: 03 Neon Auto Trans [Re: Tomsecks] #598268
01/30/10 01:05 PM
01/30/10 01:05 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
Iv done a number of them we normally get about 2500 for a full rebuild
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: 03 Neon Auto Trans [Re: dusturbd340W5] #598269
01/30/10 01:10 PM
01/30/10 01:10 PM
Byesville, Ohio
Tomsecks Offline OP
Tomsecks  Offline OP
Byesville, Ohio
Common problem I take it? Found a thread through Google where the valve body was a suggested problem. Your thoughts on that please.
Re: 03 Neon Auto Trans [Re: Tomsecks] #598270
01/30/10 05:26 PM
01/30/10 05:26 PM
Kissimmee Fl.
Kissimmee Fl.
if it doesn't move at all I doubt its the Valve Body I dont see many problems with them
Re: 03 Neon Auto Trans [Re: dusturbd340W5] #598271
01/30/10 10:21 PM
01/30/10 10:21 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
converter?
I have also heard that the trans cooler in the radiator fails and puts coolant in trans is a problem on these models.
