Comp cam question #598259
01/30/10 12:47 PM
01/30/10 12:47 PM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
looking at a Comp cam part# 20-672-4 I'm curious about the recommended components mainly the springs part #995-16 will these be ok to use with a set of stock J heads and stock stamped steel rocker arms. I'm worried about them being to strong and breaking stuff
Re: Comp cam question [Re: flatiron] #598260
01/30/10 03:13 PM
01/30/10 03:13 PM
SoCal
Brian Hafliger Offline
SoCal
That's way too much cam for stock valvetrain! You need aftermarket rockers for that cam and good pushrods.
Those springs should be used with that cam because of the rpm potential...just don't use stock rockers!!
Brian Hafliger
