kits for six pack carbs? #59819
05/19/08 07:02 PM
05/19/08 07:02 PM
E.Amherst, NY
69RR Offline OP
69RR  Offline OP
E.Amherst, NY
Does anyone know what Holley kit(s) to order to test my carbs? Its bogging at wot and probably need to change the squirters or the secondary springs.
But don't know what to order,
Any advice?
Dean Got my hands on the wheel, foot to the pedal, gonna drive this car till the tires turn to metal - gonna sleep when I'm dead and laugh at the devil..
Re: kits for six pack carbs? [Re: 69RR] #59820
05/19/08 08:10 PM
05/19/08 08:10 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
37-396 are the part numbers for the kits for 6 pack carbs.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: kits for six pack carbs? [Re: hemi71x] #59821
05/19/08 09:06 PM
05/19/08 09:06 PM
E.Amherst, NY
69RR Offline OP
69RR  Offline OP
E.Amherst, NY
Thanks!
Re: kits for six pack carbs? [Re: 69RR] #59822
05/20/08 08:44 PM
05/20/08 08:44 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
That kit will get you all the gaskets for the carb...It won't have the vacuum pod rubber diaphram or any secondary springs... You can use the holley secondary spring assortment kit{2} on the six bbl set-up to dial in the spring rate if you go that route... Here's a quick link to a secondary kit for reference.. link
Re: kits for six pack carbs? [Re: screamindriver] #59823
05/20/08 09:09 PM
05/20/08 09:09 PM
arizona, usa
lokalik Offline
lokalik  Offline
arizona, usa
not to high the post but, will the float bowls, jet plates off a holley double pumper interchange to the ouboard carbs. if so this would make rejetting easier.
Re: kits for six pack carbs? [Re: lokalik] #59824
05/20/08 09:34 PM
05/20/08 09:34 PM
Harrisburg, Pa.
Harrisburg, Pa.
Actually, the double pumper carb has a metering block at each end as well as the accellerator pumps{and would'nt work}...But I understand what you're thinking....The usual vac secondary holleys still have basically the same metering plate that's not easily adjusted{as in drilling}....But Promax and quick fuel both make the secondary metering plates that use regular jets to make tuning easier...
Re: kits for six pack carbs? [Re: screamindriver] #59825
05/20/08 10:14 PM
05/20/08 10:14 PM
E.Amherst, NY
69RR Offline OP
69RR  Offline OP
E.Amherst, NY
Thanks for the tip - I did order one - I was afraid I needed another...,
I also ordered the trick kit and 1 set of jets -
I might have to order the squirters - but they come as two per size, not sure what I'll need,
I see whats in the trick kit when it comes..
Re: kits for six pack carbs? [Re: hemi71x] #59826
05/22/08 07:57 AM
05/22/08 07:57 AM
Jasper, Indiana
fastnos Offline
fastnos  Offline
Jasper, Indiana
there is a aution on E-bay now for 3 of them.
#330090870236
You might be able to pick them up localy a little cheaper. Try running the part number on partsvoice and see if they might be cheaper also.
A True Hybrid: Burns Gas AND Rubber!
