Re: T/S Duster Build
[Re: slantzilla]
#598178
01/30/10 11:00 PM
01/30/10 11:00 PM
Quicktree
That is one sweet Duster!
you should see it in person
You gonna get to drive it Tony?
no it doesn't belong to me but it will be quite a ride when done.
[Re: '72CudaRacer]
#598179
01/30/10 11:54 PM
01/30/10 11:54 PM
Posts: 778 Sherwood park, Alberta.
go green
Hey, you're way ahead of me. I can't figure out how to put more than one picture on a post at a time, and then only if it less than so many KB thingys or something like that. Nice work on the Duster also. Brian
Copy and paste the picture info, then hit enter .
Leave a line between picture information.
It will stack to the left instead of causing a thread disaster ,
Post deleted by Defbob
[Re: JCRVETTE]
#598181
01/31/10 09:44 AM
01/31/10 09:44 AM
#598183
01/31/10 12:36 PM
01/31/10 12:36 PM
Quicktree
Thanks go green. I'll try that. Nice Cuda. As far as I know the Duster is going sublime. But, you know how that goes. Colors are subject to change several times before cars are actually painted.
Sassy Grass Green looks great on a Duster.
[Re: Quicktree]
#598186
01/31/10 06:06 PM
01/31/10 06:06 PM
Posts: 73 1/2hr south of Ocala, FL
JCRVETTE
Then sublime is the color I'm thinking of. Also, a note about the chassis/car construction. We have built just about everything in house with the exception of some brackets and tabs. Even some of those were made here, but resemble commercially available stuff. There was no kit, every tube came off the rack and was bent here, and the chassis is our design, based off some of the best features of Mcamis, Bickel, and RJ. Also the chassis is in mock-up mode, and alot of the tube and misc. haven't been done yet as I like to be sure it's all going to come together before I go to extremes. Thanks for the reply's and kind words.
[Re: JCRVETTE]
#598191
02/07/10 08:40 AM
02/07/10 08:40 AM
