Re: Line Bore Mains?
[Re: b1headman]
#598018
01/30/10 01:13 AM
01/30/10 01:13 AM
Posts: 294 Minnesota
RockChip
Minnesota
I think you should take the block back to that shop!!! thares no way that you can just bolt used caps on another block, its a verry slim chance it would work ![](/ubbthreads/images/graemlins/tsk.gif) I install all sorts of main cap stuff on brand X blocks and you usually atleast have to hone the mains back to spec, but if he never cut them then he must be trying to cut corners on you I would make them atleast double check while you watch and look for your self on that bore gauge to make shure its in spec ![](/ubbthreads/images/graemlins/rant.gif) I hope thay didnt cut anny more corners on you, I would double check everything thay did.
[Re: strokin73cuda]
#598022
01/30/10 11:23 AM
01/30/10 11:23 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
id you talk to the shop about it yet or you just got PO'd? I'd talk to "the horse" before you get all heated.
[Re: strokin73cuda]
#598024
01/30/10 12:15 PM
01/30/10 12:15 PM
Posts: 52,972 Romeo MI
MR_P_BODY
O.K. Ive cooled alittle scince last night, is there a way I can check the straightness at home? The shops not open today and I would like to have my guns loaded when I show back up at the shop.
If you dont have the equipment to check it with the most you could do is see if the cap and block have a fresh cut mark on it... if it doesnt, they most likely didnt do it.... at least a few of the mains would have signs of a cut marks( no way would they all be perfect again on a different block)..... if you have a bore gauge at home you can check the bores but still wouldnt know if its straight unless you try the crank in it..... JMO ![](/ubbthreads/images/graemlins/wave.gif)
[Re: dodgefarmer]
#598026
01/30/10 11:57 PM
01/30/10 11:57 PM
Posts: 228 northeast texas
strokin73cuda
northeast texas
My fingernail catches on two of the mains on one side heres some pics if I can get them to load this time. ![](/ubbthreads/images/graemlins/rant.gif)
496 stroker,Indy srs , new best 6.87 @ 98 1.46 60'
[Re: strokin73cuda]
#598028
01/31/10 12:10 PM
01/31/10 12:10 PM
moper
Columbia, CT
It doesn look like anything was done in them from those pics. If the caps were re-used the mating surface should have fresh cutting marks and that doesnt. Catching a nail isnt always a valid test... I deburr the edges of the cap and block very slightly so the parting line "feels" uneven and will catch a nail. Measure it properly and see what the dimensions look like.
