5.7L Hemi stumbles at idle???? #597877
01/29/10 11:22 PM
01/29/10 11:22 PM
Virginia
MACDiesel Offline OP
Virginia
I have a '07 Grand Cherokee with a stock Hemi. Sometimes at idle the RPM's will stumble and almost shut off. I just swapped the air filter to a K&N and pulled a couple of spark plugs to check them out. They look healthy. What could be the issue?
If this was the Belvedere there wouldn't be any question. But then the Belvedere doesn't have variable valve timing, multiple displacement, mpfi and all that other stuff.
-1967 Belvedere II 440/4speed
Re: 5.7L Hemi stumbles at idle???? [Re: MACDiesel] #597878
01/30/10 09:53 AM
01/30/10 09:53 AM
IN
ahy Offline
ahy  Offline
IN
Suggest taking it to a dealewr and have them hook it up to their disgnostic computer. They'll catch any codes. Also, for around $80 they can upload the latest software.
I had a similar problem with an '06 MDS hemi. It wasn't showing any codes and the new software seems to have fixed it.
Re: 5.7L Hemi stumbles at idle???? [Re: ahy] #597879
01/30/10 01:59 PM
01/30/10 01:59 PM
Tampa FL
hemibeep Offline
hemibeep  Offline
Tampa FL
Have someone test the battery. Every time a battery starts to get weak, engine acts weird.
Re: 5.7L Hemi stumbles at idle???? [Re: hemibeep] #597880
01/30/10 02:08 PM
01/30/10 02:08 PM
70duster340 Offline
70duster340  Offline
Not sure if this will pertain to your 5.7 Hemi, but my 4.7 in my Dakota was doing the exact same thing. I finally located the idle air control valve (with much help from members here, thank you very much), pulled it and cleaned it along with the throttle body. So far, no more stumbling idle problems!
Re: 5.7L Hemi stumbles at idle???? [Re: 70duster340] #597881
01/31/10 02:48 AM
01/31/10 02:48 AM
Virginia
Virginia
That's on the slate for tomorrow. We'll see if it works.
Re: 5.7L Hemi stumbles at idle???? [Re: MACDiesel] #597882
01/31/10 11:09 AM
01/31/10 11:09 AM
70duster340 Offline
70duster340  Offline
Good luck! It seems to have solved that exact same issue with my Dakota. I used some throttle body cleaner, and was quite liberal with it inside the throttle body, as well as all over the iac valve itself. The engine didn't want to run at first, I'm assuming due to the amount of cleaner that I used. But it did finally start, and has (so far) been clear of the stumbling at idle.
Keep us posted!
Re: 5.7L Hemi stumbles at idle???? [Re: 70duster340] #597883
02/02/10 08:21 PM
02/02/10 08:21 PM
70duster340 Offline
70duster340  Offline
Hey, how did the repair attempt go???
Re: 5.7L Hemi stumbles at idle???? [Re: 70duster340] #597884
02/02/10 09:01 PM
02/02/10 09:01 PM
Virginia
Virginia
Worked like a charm. Though I forgot to hook the MAF sensor back up and got a check engine light... All is well now. It idles happy.
GREAT ADVISE!
Re: 5.7L Hemi stumbles at idle???? [Re: 70duster340] #597885
02/02/10 09:03 PM
02/02/10 09:03 PM
Dayton, Ohio
W
wldtm Offline
wldtm  Offline
W
Dayton, Ohio
There is no IAC on a hemi. Could need a computer flashed, but dealer will know that by VIN.
I would be very surprised if that much carbon/deposits have built up on the throttle blade needing it cleaned. Its worth a shot though.
Justin
Interested in having you car wired? Drag car, street car, EFI swap? PM for details
Re: 5.7L Hemi stumbles at idle???? [Re: wldtm] #597886
02/03/10 02:10 AM
02/03/10 02:10 AM
Virginia
Virginia
The check ENG light went out as soon as I reconected the MAF.
As for deposits on the throttle body, it looked like it had 75,000 miles not 25,000. It was thick! Now its all clean and the Hemi is Happy.
Re: 5.7L Hemi stumbles at idle???? [Re: MACDiesel] #597887
02/03/10 07:48 AM
02/03/10 07:48 AM
70duster340 Offline
70duster340  Offline
Good to hear!!! Glad we could help!
