HP difference???? #597754
01/29/10 09:11 PM
01/29/10 09:11 PM
Kokomo,IN
StripeHOG Offline OP
Kokomo,IN
on a 450 hp motor how many HP do you think I'm losing staging at 175-180 degrees compared to 160 degrees on pump gas????
Andrew Brough D372 1969 Dodge Dart GTS 1.43 60'best 6.82 1/8 98mph "the light came on and I ran out of talent"
Re: HP difference???? [Re: StripeHOG] #597755
01/30/10 02:05 AM
01/30/10 02:05 AM
Probally none, unless the tune is way out lean or fat Try it and look at your 60 ft. times and the 330 ft times and then decide
