Steps for removing Complete dash- 71 cuda #597318
01/29/10 02:15 PM
01/29/10 02:15 PM
Avondale AZ
Prodart440 Offline OP
Avondale AZ
Can someone tell me what order to remove pieces to take the complete dash assembly out of my 71 Cuda?? Are there bolts up under the windshield also?? Thanks for the help!!!
Aaron
68 Roadrunner 383/AT
69 Dart GT Conv. 383/AT
05 Dodge Ram 4x4 Cummins
06 GoManGo R/T Daytona #757
68 Coronet 440
Re: Steps for removing Complete dash- 71 cuda [Re: Prodart440] #597319
01/29/10 05:19 PM
01/29/10 05:19 PM
ILL
Greentween Offline
Greentween  Offline
ILL
There are 4 bolts in the defroster duct area that are hard to get at with the windshield in place. Use 1/4 drive sockets with maybe a swivel. Easier to remove than put back in.
Then on the the left and right side under the kickpanel there is a bolt.
I think there is also a bracket behind the glovebox, above the heater box.
Re: Steps for removing Complete dash- 71 cuda [Re: Greentween] #597320
01/30/10 05:05 PM
01/30/10 05:05 PM
Avondale AZ
Avondale AZ
Thanks!!! It doesn't sound too hard. I will have the windsheild out when I do it.
Aaron
68 Coronet 440
Re: Steps for removing Complete dash- 71 cuda [Re: Prodart440] #597321
01/30/10 06:27 PM
01/30/10 06:27 PM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
Don't forget to unhook the fresh air vent cables from the heater core and the duct on the driver's side as well.
Drop the steering column too.
It's very easy to remove and reinstall.
Re: Steps for removing Complete dash- 71 cuda [Re: Blues_Cuda] #597322
01/31/10 12:03 PM
01/31/10 12:03 PM
Pa
GaryB Offline
super street
GaryB  Offline
super street
Pa
If you write down the sequence of removal it will make it easier to put back together.
