Fel pro 1039 on mega block #597216
01/29/10 11:19 AM
01/29/10 11:19 AM
Kentucky
sc301v Offline OP
sc301v  Offline OP
Kentucky
Anybody run fel-pro 1039 on a 4.500 mega block....The 1039 says its for a 4.590 bore....Is that gonna be to big to work??
Re: Fel pro 1039 on mega block [Re: sc301v] #597217
01/29/10 11:26 AM
01/29/10 11:26 AM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
I haven't installed it yet, but Nick at Compu-Flow recommended this gasket to me for the 4.5" Mega Block.
Re: Fel pro 1039 on mega block [Re: sixpakdodge] #597218
01/29/10 12:15 PM
01/29/10 12:15 PM
sg66mopar Offline
sg66mopar  Offline
They call it 4.590 but if you look at the hole you'll see it's not round. The last thing you want is the gasket overhanging the cylinder bores so I'd say no, it's not to big. I used Cometics on mine last season and didn't really notice the gaskets were overhanging a few thousandths until I tore it apart a couple months back. It was barely noticeable but still there. Could contribute to detination.
BTW, I would not use the Felpros with aluminum heads. The Cometics don't leave an indentation on the head like the Felpros. When I used Felpros with my Indy heads they needed to be resurfaced when the heads cam off.
I'm sure there'll be plenty who disagree but I don't want to put it back together with those grooves on the head surface. Even Brodix says Felpros are acceptable up to 12 to 1 but I won't do it again.
Re: Fel pro 1039 on mega block [Re: sg66mopar] #597219
01/29/10 12:44 PM
01/29/10 12:44 PM
Sidney,Ohio
challenger1320 Offline
Sidney,Ohio
If you are going to use a fel-pro use the 1105 it is a better gasket.
Re: Fel pro 1039 on mega block [Re: challenger1320] #597220
01/29/10 01:40 PM
01/29/10 01:40 PM
sg66mopar Offline
sg66mopar  Offline
I have a set of the 1105s I bought before I found out about the Cometics. If I had to use the Felpros that'd be the one.
Re: Fel pro 1039 on mega block [Re: challenger1320] #597221
01/29/10 01:42 PM
01/29/10 01:42 PM
Europa, Estonia
Georg Offline
Georg  Offline
Europa, Estonia
Why you even want to use this FelPro junk? Go with Cometic and you are safe. Price gap is not so big to not choose proper and good quality gasket
Outlaw Plymouth Valiant R5/P7 Powered by Liuzzo Racing COMP Performance Group dealer in Baltic Premium Performance
Re: Fel pro 1039 on mega block [Re: sc301v] #597222
01/29/10 03:49 PM
01/29/10 03:49 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
i'm using 1039,s on my 580" mega block. the bore is 4.530".it,s 14.1 cr.i use studs and have had no problems.
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: Fel pro 1039 on mega block [Re: Old School] #597223
01/29/10 03:55 PM
01/29/10 03:55 PM
UK
602heavy Offline
602heavy  Offline
UK
I'm using the fel pro 1005 (4.590" gasket bore), these will be .051" thick , had no issues with these gaskets , 500 shot of nitrous to boot.
Just modified the cooling passages in gasket due to the siamese bores.
Re: Fel pro 1039 on mega block [Re: Georg] #597224
01/29/10 04:51 PM
01/29/10 04:51 PM
Kentucky
sc301v Offline OP
sc301v  Offline OP
Kentucky
I have cometics......machine surfaces were prepared perfectly and after taking the heads off from leaking twice on a brand new motor and a can of coppercoat finally got them to stop....
Have never blew a fel-pro gasket ever and never had one to leak so thats why im goin back...And have used them up to 4 times also
Quote((Why you even want to use this FelPro junk? Go with Cometic and you are safe. Price gap is not so big to not choose proper and good quality gasket))
Re: Fel pro 1039 on mega block [Re: sc301v] #597225
01/29/10 10:13 PM
01/29/10 10:13 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
i have never had head gasket problems with the felpros,and i'm always above 13.1 or higher.
