Shop couldn't adjust caster #59709
05/19/08 02:20 PM
05/19/08 02:20 PM
Melbourne, FL
dwbiggs Offline OP
super gas
dwbiggs  Offline OP
super gas
Melbourne, FL
Said the heads, or whatever they attach to wheels, did not have enough clearance. The front end is lower and I have 17" wheels. Is there different kind of equipment that can do caster?
Re: Shop couldn't adjust caster [Re: dwbiggs] #59710
05/19/08 02:36 PM
05/19/08 02:36 PM
Kirkland, Washington
Pacnorthcuda Offline
Are they saying they DID adjust Camber and Toe?
If so, what they may have ran into was that in getting the camber set to spec (which you really DON'T want BTW)the caster ended up being less than optimum, which is common in our cars, expecially in a car that may have been crunched at some point.
If they are truly saying the didn;t have the right equipment I would be curious how they did the Camber and Toe.
Re: Shop couldn't adjust caster [Re: dwbiggs] #59711
05/19/08 02:38 PM
05/19/08 02:38 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Do you have to run the 17's (brake clearance)?
If not and they are who you want to use, swap wheels.
If not, find a place that can work with your car.
Most alignment heads stick out 3-4 inches from the wheel edge, and extend up and down maybe 20 inches. See http://www.prealign.com/images/hunterman.jpg
It could very likely have clearance issues. Different machines have different heads. You may have to check around to find a place that has the tools to work with your mods.
Re: Shop couldn't adjust caster [Re: RodStRace] #59712
05/19/08 03:10 PM
05/19/08 03:10 PM
Melbourne, FL
dwbiggs Offline OP
super gas
dwbiggs  Offline OP
super gas
Melbourne, FL
They were able to do toe-in and camber but the guy said that in order to do caster the head had to be ratated like 30 deg both ways but the heads would not clear the fender? Something like that anyway.
Re: Shop couldn't adjust caster [Re: Pacnorthcuda] #59713
05/19/08 03:25 PM
05/19/08 03:25 PM
Melbourne, FL
dwbiggs Offline OP
super gas
dwbiggs  Offline OP
super gas
Melbourne, FL
They did get camber and toe...1" neg camber and 1/16" toe.
Re: Shop couldn't adjust caster [Re: dwbiggs] #59714
05/19/08 03:34 PM
05/19/08 03:34 PM
GOOD numbers there! (You don't want postive camber, even though stock specs are positive) If you didn't tell them you wanted 1 degree neg then they already knew---thats a GOOD sign. Sounds like they don't have the right head style to clear your fenders with your 17 inchers.
Re: Shop couldn't adjust caster [Re: Pacnorthcuda] #59715
05/19/08 04:02 PM
05/19/08 04:02 PM
Melbourne, FL
dwbiggs Offline OP
super gas
dwbiggs  Offline OP
super gas
Melbourne, FL
I actually told them what numbers I wanted....they had to create a "custom" alignment in the database. I think I will try to find someone who can do the caster...was just wondering which type of machine can do it so I know what to ask for. The guy at the shop mentioned a different type of machine that could do it.
Re: Shop couldn't adjust caster [Re: dwbiggs] #59716
05/19/08 05:56 PM
05/19/08 05:56 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
They're right when you turn the wheels on a lowered car the heads can get close. If it steers straight and camber & toe are good I wouldn't worry about it.
Doug
Re: Shop couldn't adjust caster [Re: dvw] #59717
05/19/08 06:15 PM
05/19/08 06:15 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
Can caster be adjusted without affecting camber since they are on the same 2 bolts, or would the camber need to be reset after turning the bolts?
Re: Shop couldn't adjust caster [Re: dvw] #59718
05/19/08 07:22 PM
05/19/08 07:22 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Doug
Re: Shop couldn't adjust caster [Re: Exit1965] #59719
05/19/08 07:25 PM
05/19/08 07:25 PM
No. The same two bolts. One affects the other.
Re: Shop couldn't adjust caster [Re: Pacnorthcuda] #59720
05/19/08 10:53 PM
05/19/08 10:53 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
You have to do camber and caster adjustments at the same time.
Try finding a shop that has a Hunter DSP 4000 or newer machine. I use a DSP 4000 at work and I cant remember the last time I had a problem with getting the heads to mount or read.
Re: Shop couldn't adjust caster [Re: WILD BILL] #59721
05/20/08 08:15 AM
05/20/08 08:15 AM
Melbourne, FL
dwbiggs Offline OP
super gas
dwbiggs  Offline OP
super gas
Melbourne, FL
Now thats the answer I was looking for...thanks!
I notice that the car darts a little when I go over a ridge in the road...sorta like driving on the old bias ply tires. I assume this is due to a caster adjustment...since the tires are new and my camber and toe in are now correct.
Re: Shop couldn't adjust caster [Re: dwbiggs] #59722
05/20/08 09:16 AM
05/20/08 09:16 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
i don't do alignments for a living but my buddy lets me use his alignment machine to do alignments on my car.
to the best of my knowledge you have to do a caster swing to get any readings, including camber and toe, from the alignment machine. how were they able to get the other readings without doing a caster swing.
they have a hunter hawkeye machine at the dealer where i work. according to the alignment guy this machine can do alignments on all cars with wheels up to 24" big.
perception is 90% of reality
Re: Shop couldn't adjust caster [Re: Mr T2U] #59723
05/20/08 11:13 AM
05/20/08 11:13 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Thing is, when you find a shop with the right equiptment, they will likely have to redo the camber and toe too. They'll probably have to start all over again.
Not having the caster equal or close will cause the car to pull at cruise speed.
My car is lowered with 15" wheels though. Not a problem. I don't see how 17" rim would make a difference in the setup shown in my picture...
Re: Shop couldn't adjust caster [Re: autoxcuda] #59724
05/20/08 12:18 PM
05/20/08 12:18 PM
Melbourne, FL
dwbiggs Offline OP
super gas
dwbiggs  Offline OP
super gas
Melbourne, FL
My car is way lower than that....probably 3" lower. Think he had to put extension on them for my 17"'s and that put them too close to fenders.
Re: Shop couldn't adjust caster [Re: dwbiggs] #59725
05/20/08 02:49 PM
05/20/08 02:49 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I need to make one small correction due to my bad memory. The alignment machine is a DSP 400 not 4000.
Sorry if that caused any confusion.
Re: Shop couldn't adjust caster [Re: Mr T2U] #59726
05/20/08 05:05 PM
05/20/08 05:05 PM
N
NITROUSN Offline
NITROUSN  Offline
N
That what I was thinking.
Re: Shop couldn't adjust caster [Re: dwbiggs] #59727
05/20/08 06:59 PM
05/20/08 06:59 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Put a set of 14's or 15's on the car and get it aligned, and DON'T let them change your torsion bar settings then swap out to the 17's. Make sure the t bars are set correctly with the 17's before the alignment. The alignment should not change provided the car is on the same size tires on all 4 corners with the 14's / 15's and then to the 17's.
Re: Shop couldn't adjust caster [Re: Sixpak] #59728
05/20/08 08:08 PM
05/20/08 08:08 PM
ky.
K
kenworth_goose Offline
K
ky.
What they are telling you they can't adjust the caster because they can't do a caster sweep for a base measurment which is necessary before any adjusting.
