what's the deal with tubes being put in tires? #597130
01/29/10 10:57 AM
01/29/10 10:57 AM
ME
79machocharger Offline OP
ME
I've got a couple of decent polyglas tires I want to use but they wont keep air, is it safe to put tubes in them and use them them for driving?
Re: what's the deal with tubes being put in tires? [Re: 79machocharger] #597131
01/29/10 11:00 AM
01/29/10 11:00 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
why won't they hold air? and how old are they? I guess you could use tubes. I'd get repo's if you want the look. I'd be a litted worried about driving on something like those. One hard stop, one hard turn and they might just come all apart.
Coming soon!!!!
Re: what's the deal with tubes being put in tires? [Re: Mr.Yuck] #597132
01/29/10 11:20 AM
01/29/10 11:20 AM
ME
ME
I'm not quite sure, they look fine but there leaking air from some where really slow.
Re: what's the deal with tubes being put in tires? [Re: 79machocharger] #597133
01/29/10 11:26 AM
01/29/10 11:26 AM
We do it in our circle burners because the pressures are so low and going around the corners they'd leak out otherwise. I think you could tube them for daily driving but might check the leak points as in new valve stems & vigorously wire wheel smoothing the sealing beads on the inside of each side of the rim and checking the bead of the tire itself(no bumps/needs to be smooth) and lightly sanding if need be.
Re: what's the deal with tubes being put in tires? [Re: RapidRobert] #597134
01/29/10 11:46 AM
01/29/10 11:46 AM
WI
W
wannadrag Offline
wannadrag  Offline
W
WI
The rubber on the beads gets hard and wont seal.Tubes will work,i do it on ocassion.Before you install check the sidewalls for cracks and not just by looking,you need to apply some pressure.Any cracks at all give em a pitch.
Re: what's the deal with tubes being put in tires? [Re: wannadrag] #597135
01/29/10 11:49 AM
01/29/10 11:49 AM
ME
ME
Cool thanks for the info guys, wasn't really sure.
Re: what's the deal with tubes being put in tires? [Re: 79machocharger] #597136
01/29/10 12:44 PM
01/29/10 12:44 PM
Wilmington, NC
donbarnes Offline
Not THAT Don Barnes!!
donbarnes  Offline
Wilmington, NC
They would still work as a cool looking spare with a tube even if your're not comfortable running them on the street full time..Back when I lived in Arkansas I found a very old raised white letter "Arkansas Razorback" tire in an old barn and put it on a Chevy rally wheel and used it as a spare, great conversation piece
Re: what's the deal with tubes being put in tires? [Re: donbarnes] #597137
01/29/10 01:30 PM
01/29/10 01:30 PM
St. Louis Mo.
10 o to go Offline
"Happy Don"
10 o to go  Offline
"Happy Don"
St. Louis Mo.
In the drag world some put dawn detergent rub it throught out the tire let dry mount them try it. No liability written or implied .
2009 418" build dan smith built new 9.96 131.82 6.23 108 1.30 60 foot best to date 9/15/09 8in 727 430 dana 2860 lb 3040 lb w driver
Re: what's the deal with tubes being put in tires? [Re: 79machocharger] #597138
01/29/10 05:07 PM
01/29/10 05:07 PM
Rome, PA
Ryan_340 Offline
Ryan_340  Offline
Rome, PA
I would try to find out were they are leaking, possibly a rim bead leak?
1972 Power Wagon W100 1973 Power Wagon W200 1971 Duster 1972 Dart Swinger 3-1972 Demons
Re: what's the deal with tubes being put in tires? [Re: 79machocharger] #597139
01/29/10 05:22 PM
01/29/10 05:22 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
Way back in a previous life I did alignments at a large chain store.
The company policy was that tubes do NOT go into tubeless tires. The claim was that it would build up heat beyond the level that the tire was designed for. Seemed reasonable to me.
On the other hand, it could also have been over-the-top CYA.
I would make the argument that aging, dry tires that don't seal well at the bead or somewhere else are already a concern that should keep their use and speed to minimums, even before any concerns about heat build-up from adding tubes.
Down to just a blue car now.
Re: what's the deal with tubes being put in tires? [Re: 68HemiB] #597140
01/29/10 05:43 PM
01/29/10 05:43 PM
IL . usa
cjs69mope Offline
cjs69mope  Offline
IL . usa
hey when i first started in the auto business my mentor and very good mechanic Friend who took me under his wing taught me how to stop rim leaks was to clean the rim with scotch brite disk and with your finger rub used motor oil into the bead of the tire just before you install it on the tire machine
the oil will soften the bead and it will seal it .
done this many times on cars with badly pitted rims that other shops said were junk and never !honest never had one come back !
I would not do this on a race car but street car i have been doing this for over 20 yrs . no problems yet .
1969 Dodge Charger 1969 Dodge Superbee
Re: what's the deal with tubes being put in tires? [Re: cjs69mope] #597141
01/29/10 06:06 PM
01/29/10 06:06 PM
with your finger rub used motor oil into the bead of the tire the oil will soften the bead and it will seal it.
I'll try that as I have one w a slow leak and talcum powder on the tube will stop heat buildup
Re: what's the deal with tubes being put in tires? [Re: RapidRobert] #597142
01/30/10 01:31 AM
01/30/10 01:31 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
I have dont it a couple of times with tires that had non repairable punctures in the sidewall or close to the sidewall.
Put a patch on the inside and a tube in it. No problems.
I agree with the others tho, it is most likely a rim leak. The local tire shop fixed the one on my jeep by cleaning the wheel and brushing on liquid cement, for rubber patches..
OR just slime it...and be done..
Re: what's the deal with tubes being put in tires? [Re: sthemi] #597143
01/30/10 02:52 PM
01/30/10 02:52 PM
A certified culture free zone.
74RALLYE Offline
74RALLYE  Offline
Slime (the green stuff) has worked very well for me on crappy wheel barrow tires, old boat trailer tires and yard cars.
