have 906 heads right now should I go to stealth heads? #59677
05/19/08 02:15 PM
05/19/08 02:15 PM
ME
79machocharger Offline OP
ME
I have a set of 906 heads right now and was wondering if it would be worth it for me to spend $900.00 for the stealth heads. Do they really make that much of a difference. My 906 heads are going to need to be gone through. What are the advantages. Are they going to really give me that much more hp.
Thanks for any help
Re: have 906 heads right now should I go to stealth hea [Re: 79machocharger] #59678
05/19/08 02:50 PM
05/19/08 02:50 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
it's going to cost you that much or close to that just to do a stock rebuild on a set of 906's , the choice is up to you as to what you do once you receive the new heads , meaning have them checked over , or take your chances and run them as is .
Re: have 906 heads right now should I go to stealth hea [Re: JohnRR] #59679
05/19/08 03:13 PM
05/19/08 03:13 PM
dogdays Offline
dogdays  Offline
Before you spend a nickel on your 906s get a WRITTEN QUOTE from a reputable shop and compare it with the price of a set of new heads. Keep in mind that the 906s will require quite a bit of porting to flow with the aftermarket heads and porting doesn't come cheap.
R.
Re: have 906 heads right now should I go to stealth heads? [Re: 79machocharger] #59680
05/19/08 05:00 PM
05/19/08 05:00 PM
if it was my decision.. i'd spend the coin on the 906's. nuttin like factory iron.
advantage ussually goes to the aluminum heads. both for weight and gettin away with a
bit more c/r. but when the porting tools come out, there both gonna cost $$$. but as
JohnRR said, check and fix whats needs done, or take your chances and run either head "as is".
Re: have 906 heads right now should I go to stealth heads? [Re: 79machocharger] #59681
05/19/08 05:43 PM
05/19/08 05:43 PM
Kirkland, Washington
Pacnorthcuda Offline
The HP potential of stealth vs. 906 can and has been debated to great length. Some situations simply don't warrant extra effort or $$$ for better flow numbers (I don't know the particulars of your engine build, so that may or may not apply to you) BUT, the weight savings is REAL, and its real for all situations--less so for some 4500# + luxo barge.
Weight saving is arguably better than increased power output because less weight means faster acceleration, faster deceleration, better handling, and more mpg. More power USUALLY only equates to faster acceleration.
To me, it doesn't make sense to spend similar money on heads and ignore the weight advantage. Its there waiting for you....take it.
And after all, its not like the Stealth option is likely to make LESS power!!!
Re: have 906 heads right now should I go to stealth heads? [Re: Pacnorthcuda] #59682
05/19/08 08:17 PM
05/19/08 08:17 PM
At a gas station near you
badblack68 Offline
badblack68  Offline
Call Bob at Outrageously Vintage in Searsmont. He`ll tell you the real story on 906 heads verses "stealth" heads. www.outrageouslyvintage.com
Re: have 906 heads right now should I go to stealth heads? [Re: badblack68] #59683
05/19/08 09:35 PM
05/19/08 09:35 PM
Fairfield Maine
hemi4speed Offline
hemi4speed  Offline
Fairfield Maine
it wont cost you a dime Ryan for the advice..and Bob is as honest and as knowlegeable as the come..
Re: have 906 heads right now should I go to stealth heads? [Re: 79machocharger] #59684
05/19/08 10:15 PM
05/19/08 10:15 PM
Mid Michigan
Coronet-R/T-Rag Offline
Mid Michigan
I would get the stealth or eddy heads. Your 906's are close to 40 years old and have had thousands of heat cycles. They will crack one of these days (especially after you port them). After that you have some cool doorstops that flow really good.
Re: have 906 heads right now should I go to stealth heads? [Re: Coronet-R/T-Rag] #59685
05/19/08 11:23 PM
05/19/08 11:23 PM
Carroll,Iowa 51401
Cyl.Porter Offline
Cyl.Porter  Offline
Carroll,Iowa 51401
I would go with the Stealth heads. They are much beeter than the stock 906's. You have old technology that is whay out dated for the times. You will actually spend more on the 906's than you would ever spend just buying the Stealth heads. I use to work in a machine shop. And what Coronet R/T said about the heating cylces is true. The stealth heads are a good head for the money.
Re: have 906 heads right now should I go to stealth hea [Re: Cyl.Porter] #59686
05/19/08 11:28 PM
05/19/08 11:28 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
But will the stealth heads work on a 383? or are the valves too big?
Re: have 906 heads right now should I go to stealth hea [Re: moparpollack] #59687
05/19/08 11:40 PM
05/19/08 11:40 PM
Carroll,Iowa 51401
Cyl.Porter Offline
Cyl.Porter  Offline
Carroll,Iowa 51401
Dont know the 383 has a 4.25 bore while the 440 has a 4.32 bore. Check with your machine shop and ask them. I think it should work. Look for my add in the section for business. It's called Shotties Porting Services and give me a call
Re: have 906 heads right now should I go to stealth hea [Re: moparpollack] #59688
05/20/08 07:53 AM
05/20/08 07:53 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
they will be fine on that bore size , adding a notch to unshroud the valves like the factory did on the max wedge engines in 63/64 would help ,but is probably not necessary
Re: have 906 heads right now should I go to stealth hea [Re: JohnRR] #59689
05/20/08 08:02 AM
05/20/08 08:02 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Way back in the mid nineties one of the magazines had DLI (Dick Landy Industries) do up a set of 452s. Nice porting some polishing, new oversize valves ect ect. The cost for this back then was approaching 2 grand and that was being done to your supplied cores. The stealth heads may not be made in America, but neither are alot of new Fords Chivies and Dodges.
Keep old mopars alive.
Re: have 906 heads right now should I go to stealth hea [Re: 2boltmain] #59690
05/20/08 08:10 AM
05/20/08 08:10 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
why not look online or a swap meets for a set of working pre-owned heads? 915, 906, 452. Doesn't really matter. Depending on what you want out of the car. If you plan on building up the 383 later or going with a 440 at some time the Stealth heads wouldn't be a bad idea. However you can pick up a set of ported iron heads for 3-500.
Re: have 906 heads right now should I go to stealth hea [Re: Mr.Yuck] #59691
05/20/08 11:36 AM
05/20/08 11:36 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
i'll buy all the sets you have for that .
Re: have 906 heads right now should I go to stealth hea [Re: JohnRR] #59692
05/20/08 12:03 PM
05/20/08 12:03 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Paid $500 for my Hensley ported 2.14/1.81 valved 516's hardley used w/ really good flow numbers. I've also seen nice 906's and 452's for about the same or less.
Re: have 906 heads right now should I go to stealth heads? [Re: 79machocharger] #59693
05/20/08 01:08 PM
05/20/08 01:08 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I can't believe some of these responses. It amazes me that these guys are actually driving cars and not still running around in horse and buggys!
Use the 906's to anchor your dingy or something like that - or sell them to one of these die-hard iron fans. The simple fact is you'll end up spending more money than the cost of the Stealth heads to get a 906 to perform to the same level as an "out of the box" Stealth (just read the specs !!) and then you'll be left with very little room for future improvement. The Stealth, on the other hand, has all the good stuff right out of the box AND has a ton of material left for future improvement. The weight savings was already mentioned. Consider resale value as well. "Brand new" should also be worth something!
As for asking so-and-so about this and so-and-so about that, HELL, call up 440Source and get it right from the horse's mouth !!!!!
Re: have 906 heads right now should I go to stealth heads? [Re: Stanton] #59694
05/20/08 01:19 PM
05/20/08 01:19 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
If he doesn't plan on building a 600 Hp motor why should he spend over 1k on a set of heads? Why does everybody need aluminum heads? If I was going to build an engine that required those flow numbers sure I'd buy a set. But if I building a simple 440 or 383 for fun and a few track dates I'll save the $$$ for something else.
Re: have 906 heads right now should I go to stealth heads? [Re: 79machocharger] #59695
05/20/08 02:24 PM
05/20/08 02:24 PM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
All good points above.
I say fit the parts to the budget no matter what it is. If you can swing the Stealth heads go for it, if not look for some already worked 906 heads. If you have to rework your heads to the tune of new seats, valves and a valve job then I think you are close enough to where the smart money in on the stealth heads. If you have a bigger budget then go for an indy head and so on...
Don't spend more than you can afford, you don't need to. And don't spend 75% of the cost of a new part reconditioning a new one.
ken
Re: have 906 heads right now should I go to stealth heads? [Re: Mr.Yuck] #59696
05/20/08 02:35 PM
05/20/08 02:35 PM
So. Cal. For Now But Texas Bou...
69sixpackbee Offline
I'll throw in my $.02.
I took delivery of one of the first sets of stealths. Took them all apart and checked them THOROUGHLY. Not bad. I checked each valve with Dykem to confirm seat sealing. A few spins with the hand lapper showed all but one were spot on. After a few trips to the head surfacing machine I dialed in my chambers to 74'cc. I then started blending in the already ample (stock-ish form) bowls to the valve inserts as they (the inserts) protruded a bit into the bowls. I polished up the ports and knocked down the casting flash in them as well as an intake gasket match. I ended up removing .060" on the surfaces and .075" on the intake faces. Some of the valve cover rail was milled off in doing so but still have plenty of meat to seal the valve cover. After hand lapping the questionable valve, putting in my Isky 935-DR springs from my "906"'s and a brand new set of Comp Cams 10-degree retainers and locks, they were good to go.
I figured I spent about 6hrs with the "Tootsie Rolls" which included relieving the intake pushrod areas for use with 3/8" rods and 1.6:1 rockers, another 2+ hrs for setup and about $200.00 in maching and parts costs and I am still a few bucks ahead.
I don't think you can beat the cost factor. I too am not looking for a balz out killer RB just a decent runner in a stock-bodied "B" body with enough punch to turn some heads. I was running 12.70's before the head swap so soon I will send it down the track to see what improvements I made.
I went from 9.6:1 CR with the old iron heads to 10.5: 1 with the "Stealth's". I have a .048" quench (attainable using Cometic's and a stock deck ht.) and "Sixpack" 2355F TRW flattops. I have the .509/.292 cam "straight up", 3000 stall converter and 4.10"s in the Dana.
Hopefully I will drop the mill into the car this weekend.
Lots have been said about the Stealths but I still feel I got a good deal. No head swap is without a fair amount of work and exterraneous cash outlay. That is a given.
Good luck!
Bud
