thread size on holley fuel bowl screw? #596472
01/28/10 01:33 PM
01/28/10 01:33 PM
Charleston
sixpackgut Offline OP
Drag Week Mod Champion
Charleston
what is it? 12-24 i need some coils and i'm at work
Re: thread size on holley fuel bowl screw? [Re: sixpackgut] #596473
01/28/10 01:35 PM
01/28/10 01:35 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
what is it? 12-24
Yep! 12-24
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: thread size on holley fuel bowl screw? [Re: 68LAR] #596474
01/31/10 12:24 AM
01/31/10 12:24 AM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
heli-coil makes a kit for 12-24 you can get it @ napa. I have one at my shop, I could give you the part # tomorrow. Don
Re: thread size on holley fuel bowl screw? [Re: cudadon] #596475
01/31/10 03:48 AM
01/31/10 03:48 AM
Charleston
Charleston
repaired. thanks bought at napa
Re: thread size on holley fuel bowl screw? [Re: sixpackgut] #596476
01/31/10 10:05 AM
01/31/10 10:05 AM
Richmond Va, KeislerTKO 60...
V
VanishPt Offline
VanishPt  Offline
V
you can also use the 12-24 to repair a stripped shooter hole. You would just need to use a hollow bolt . The 12-24 is close enough to the 12-28( the correct size) that it will work.
