ball joint torsion bar tool?? #596050
01/27/10 09:12 PM
01/27/10 09:12 PM
MOORESVILLE NC
69four46 Offline OP
69four46  Offline OP
MOORESVILLE NC
Is this a ball joint or torsions bar tool?? it is huge and weighs a ton. Any help would be greatly appreciated.
Re: ball joint torsion bar tool?? [Re: 69four46] #596051
01/27/10 10:12 PM
01/27/10 10:12 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
I don't see how it could be either.
If its large enough, could it be a king pin press?
I've worked on autos and large trucks for over 30 years, but I don't recall ever seeing one of those.
Brian
Re: ball joint torsion bar tool?? [Re: '72CudaRacer] #596052
01/27/10 10:16 PM
01/27/10 10:16 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Upper ball joints screw in with a large 4 sided socket and lower bolt on...
Torsion bars are adjusted with a socket on the adjuster..
Re: ball joint torsion bar tool?? [Re: 69four46] #596053
01/27/10 10:22 PM
01/27/10 10:22 PM
moparx Offline
moparx  Offline
looks like a kingpin press.
Re: ball joint torsion bar tool?? [Re: 69four46] #596054
01/27/10 11:29 PM
01/27/10 11:29 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
It's a ball joint press.
I have one of those also, but you have only pictured the main body of the tool.
There are numerous "drivers" and "sockets"
that are needed with that tool to get out different pressed in ball joints.
RF-4C Phantom 69-370 Zweibrucken, Germany
