ebody 3 speed question #595958
01/27/10 08:02 PM
01/27/10 08:02 PM
ME
79machocharger Offline OP
ME
We have a 70 barracuda slant six parts car and I was wondering if I could use the 3 speed tranny in it for my 318 in my 70 challenger? What would it take it or will it not work? I trying to build this with parts that we have kicking around the shop.
Re: ebody 3 speed question [Re: 79machocharger] #595959
01/27/10 08:03 PM
01/27/10 08:03 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Nope, slant 6 uses different bellhousing pattern than small block v8.
Re: ebody 3 speed question [Re: DaytonaTurbo] #595960
01/27/10 08:06 PM
01/27/10 08:06 PM
ME
ME
What if I use a 318, 340 bell housing would it work?
Re: ebody 3 speed question [Re: 79machocharger] #595961
01/27/10 08:43 PM
01/27/10 08:43 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
yeah. that trans would work, if you have a smallblock bellhousing.
Re: ebody 3 speed question [Re: volaredon] #595962
01/27/10 09:04 PM
01/27/10 09:04 PM
yes, most likely an "A230" and if so it will have "A230" on a machined pad on one side of the trans. It is synchro'd in 1st & is a tough trans. The /6 oe ones are 3.08-1st, 1.70 2nd. The oe V8 one is 2.55-1st. 1.49-2nd.
Re: ebody 3 speed question [Re: volaredon] #595963
01/27/10 09:05 PM
01/27/10 09:05 PM
warfordsburg, PA
dirt Offline
dirt  Offline
warfordsburg, PA
yes you just need a smallblock bellhousing. most of the 4 speed bellhousings i have seen also have the 3 speed mounting pattern on them too.
Re: ebody 3 speed question [Re: dirt] #595964
01/27/10 09:08 PM
01/27/10 09:08 PM
MOORESVILLE NC
69four46 Offline
69four46  Offline
MOORESVILLE NC
I have a v-8 three speed bellhousing if you need it part number 2536940
Re: ebody 3 speed question [Re: 79machocharger] #595965
01/28/10 12:54 PM
01/28/10 12:54 PM
Southeast Wisconsin
Sunroof_Cuda Offline
Southeast Wisconsin
The later 3 speed bellhousings have dual pattern for both the 3 speed and 4 speed. Notice the 3 speed is a square pattern, while the 4 speed has an offset bolt hole. My experience is that the dual pattern was introduced around 1972. Any later bellhousing, including the pretty abundant ones from trucks, should work. I have several.
