Re: dana 60 axle gasket/seal
[Re: Snoopy]
#595667
01/27/10 02:42 PM
01/27/10 02:42 PM
Posts: 8,850 Central Coast, Calif.
Snoopy
The 2070933 is listed in the 68 TSB and the brake section of the 70-71 parts books as 7/64" foam gasket. Actually it is listed as foam in the TSB and 7/64" in the parts book. The 2881314 gasket is listed in the 68 TSB and in the parts packages section of the 70-71 parts book, but not in the axle section. It appears that the listing in the axle section of p/n 2070933 is in error. It should be 2881314. I am going to go lay down now, I am feeling very confused.
