Re: 68-9/70 brake lines.
[Re: Mr.Yuck]
#59566
05/19/08 02:42 PM
05/19/08 02:42 PM
Posts: 75,012 U.S.S.A.
JohnRR
U.S.S.A.
The fine lines fit the 8.75 that was in the car (70 Charger) but the rear I was putting in was from a 68 RR. I just cleaned up and re-used the original lines. (68 rear) The "T" block is in a different place. Now I have to ask myself, do I buy a hose for a 70 Charger or a 68 RR???
depends , is the body line stop in the same spot for a 68 rr as a 70 charger .
they did the same thing on a bodies , maybe the same year , moved the T block , i redrilled and tapped the axle to put the line in the proper place for the car i was working on as i am pretty sure the line is listed as different also
[Re: JohnRR]
#59567
05/19/08 02:44 PM
05/19/08 02:44 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
No idea but I do have access to a few nice 68 RR's . I'll have to do a little looking.
