Fuel cell in the trunk? #595315
01/27/10 09:40 AM
01/27/10 09:40 AM
St. Clair Shores, Michigan
bigsbigelow Offline OP
Does a fire wall have to be made between the trunk and passenger compartment if I have my fuel cell mounted in the trunk? I have a back seat, by the way.
Ryan "Bigs" '73 Duster (BLKDUST) - Black, 100% factory sheet metal, flat hood, 346 cid, J Heads, and a bench seat. http://s268.photobucket.com/albums/jj1/bigsbigelow/ Best to date: 12.40 @ 109 mph
Re: Fuel cell in the trunk? [Re: bigsbigelow] #595316
01/27/10 09:48 AM
01/27/10 09:48 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Yes!
Re: Fuel cell in the trunk? [Re: Dodgem] #595317
01/27/10 09:59 AM
01/27/10 09:59 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes!
Like said plus it has to be a certain thickness either
steel or alum(I dont have a book to see the spec)
Re: Fuel cell in the trunk? [Re: MR_P_BODY] #595318
01/27/10 10:07 AM
01/27/10 10:07 AM
Yes!
That is what I thought. I have some .060 steel I was able to grab from work but don't know if it is over kill. I don't want to add any unnecessary weight.
Re: Fuel cell in the trunk? [Re: bigsbigelow] #595319
01/27/10 10:13 AM
01/27/10 10:13 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes!
Thats over kill... the spec is something like .024
steel and .035 alum(dont quote me on this)
Re: Fuel cell in the trunk? [Re: MR_P_BODY] #595320
01/27/10 10:15 AM
01/27/10 10:15 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I'd like to know the required thickness as I'm going to remove my factory plywood fold down in my fastback.
I'd prefer the required aluminum thickness info if anybody has it available.
Re: Fuel cell in the trunk? [Re: roadhazard] #595321
01/27/10 10:22 AM
01/27/10 10:22 AM
MR_P_BODY Offline
MR_P_BODY  Offline
This is from a older book but I dont think its
changed.... .032 alum or .024 steel
Post deleted by moparts [Re: MR_P_BODY] #595322
01/27/10 10:25 AM
01/27/10 10:25 AM
Re: Fuel cell in the trunk? #595323
01/27/10 10:28 AM
01/27/10 10:28 AM
Dang, I guess I need to pony up a few bucks for a sheet of .032 aluminum.
Re: Fuel cell in the trunk? [Re: bigsbigelow] #595324
01/27/10 10:31 AM
01/27/10 10:31 AM
MR_P_BODY Offline
MR_P_BODY  Offline
It would be worth the money VS the .060 steel, that
would be a fair amount of weight difference
Re: Fuel cell in the trunk? [Re: MR_P_BODY] #595325
01/27/10 10:44 AM
01/27/10 10:44 AM
I actually made a mistake. I have .030 steel. I was offered a sheet of .060 and .030. Obviously I took the .030 because the .060 sheet is still here at work. Brain fart. I guess I will use the steel I have. It was free.
I'll take some pics so you guys can critique my work.
Re: Fuel cell in the trunk? [Re: bigsbigelow] #595326
01/27/10 12:33 PM
01/27/10 12:33 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
The rule book also states Fuel tanks, pumps, lines, valves etc. must be outside of the Drivers compartment.
So if you have any fuel related components in the trunk you must have the firewall and everything must be sealed. Speaker holes etc.
SRT DEMON ONE SEAT
Re: Fuel cell in the trunk? [Re: bigsbigelow] #595327
01/27/10 06:49 PM
01/27/10 06:49 PM
Fort Worth, TX
Dago Red Offline
Dago Red  Offline
Fort Worth, TX
Big, you've got it made. Just be glad you're not running a station wagon.
I spent big bucks for a dirt track cell in a steel container, check valves, breakaway fittings etc. Trying to explain the container IS the bulkhead is,well,ya just can't buy that kind of entertainment
If You Can't Be Good, At Least Be Colorful
Re: Fuel cell in the trunk? [Re: MR_P_BODY] #595328
01/27/10 06:55 PM
01/27/10 06:55 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Thanks I appreciate the help on that
Re: Fuel cell in the trunk? [Re: bigsbigelow] #595329
01/27/10 07:00 PM
01/27/10 07:00 PM
heres my divider made out of aluminum.
