904/500 low gear set interchange??? #594484
01/26/10 01:48 PM
01/26/10 01:48 PM
Spring Grove, PA, US
Mr.Mopar Offline OP
Mr.Mopar  Offline OP
I went to the junkyard today, and came across a A500 trans laying in the back of a ramcharger, and i didnt think about it till i got home.. would the low gear set out of a 90's A500 fit a 70's A904 trans?? it would be awesome to have that extra gear pulling out
1996 cummins diesel ext cab, long bed
1966 Valiant 4dr(318- 3.55gears, 13.31@ 102mph),
1974 Duster(360- 13.63@ 99.96 w/3.23 gears),
1933 Dodge DP (201)
Re: 904/500 low gear set interchange??? [Re: Mr.Mopar] #594485
01/26/10 11:12 PM
01/26/10 11:12 PM
Temecula, Ca.
Z
zzyzxpat Offline
zzyzxpat  Offline
Z
Temecula, Ca.
You will never notice the difference.
" The last official act of any goverment, is to loot the treasury" George Washington
Re: 904/500 low gear set interchange??? [Re: zzyzxpat] #594486
01/27/10 06:49 AM
01/27/10 06:49 AM
Mr.Mopar Offline OP
Mr.Mopar  Offline OP
well.. i went from 2.94 gears to 3.23 in my duster and i went from 14.0 to 13.6 at the track...
so I would think that changing the gear ratio in the trans would do about the same thing..
can anyone tell me if the parts will fit??
1933 Dodge DP (201)
Re: 904/500 low gear set interchange??? [Re: Mr.Mopar] #594487
01/27/10 09:47 AM
01/27/10 09:47 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
they should, I think you may need the drum from the LG tranny, too...Hopefully John Kunkel will chime in...he seems to be the answer man for torqueflights.
2017 Grand Cherokee Overland
Re: 904/500 low gear set interchange??? [Re: Mr.Mopar] #594488
01/27/10 09:53 AM
01/27/10 09:53 AM
Temecula, Ca.
Z
zzyzxpat Offline
zzyzxpat  Offline
Z
Temecula, Ca.
Yes the parts will fit. You need the front ring gear and hub assy, the front planet, and the sun gear/shell assy. It's a drop in replacement.
I am sure changing gears in the diff did change your E.T. That changes the RPM throughout the entire range. Changing the gears in the trans changes 1st gear ratio only.
Re: 904/500 low gear set interchange??? [Re: zzyzxpat] #594489
01/27/10 10:34 AM
01/27/10 10:34 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
that is incorrect - it changes 1 & 2
Re: 904/500 low gear set interchange??? [Re: DJVCuda] #594490
01/27/10 01:26 PM
01/27/10 01:26 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
yup, older 904's are 2.45/1.45/direct, newer ones are 2.74/1.54/direct
Re: 904/500 low gear set interchange??? [Re: patrick] #594491
01/27/10 03:18 PM
01/27/10 03:18 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
THANKS!
Re: 904/500 low gear set interchange??? [Re: Mr.Mopar] #594492
01/27/10 03:25 PM
01/27/10 03:25 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
ok so lets do some math, if he has a 904 with 3.23 gears and he adds the lower gear set to this trans, what would be his new first and second drive ratio, then for kicks add the a500 OD final ratio, lets keep everything equal.
Re: 904/500 low gear set interchange??? [Re: Dakota_Don] #594493
01/27/10 04:13 PM
01/27/10 04:13 PM
houston texas
gremlinsteve Offline
houston texas
the 999 amc wil also interchange.
steve
if You Like Gremlinsteve. Gremlinsteve Likes You.
Re: 904/500 low gear set interchange??? [Re: Dakota_Don] #594494
01/27/10 06:14 PM
01/27/10 06:14 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
math is easy...2.74*3.23=8.8502
8.8502/2.45= 3.61
so overall 1st gear will act like it's a standard trans with a 3.61 rear.
do the same math for 2nd if you're curious.
3.23*0.69 = 2.23, or overall gearing like 3rd in a late model M (which used 2.21 gears mainly)
Re: 904/500 low gear set interchange??? [Re: Mr.Mopar] #594495
01/27/10 06:14 PM
01/27/10 06:14 PM
Mr.Mopar Offline OP
Mr.Mopar  Offline OP
glad to hear the parts should work!
I'll try to get them this weekend. And i did know that it only changes first and second. I just think it would be nice to have basically an "extra" gear in fisrt for pulling out at the track, then on the street your 3rd gear is still the same.
1933 Dodge DP (201)
