Any sticky valve additives actually work? #59448
05/19/08 01:21 AM
05/19/08 01:21 AM
California
P
polkat Offline OP
mopar addict
polkat  Offline OP
mopar addict
P
California
Looking for a temporary fix for a sticking lifter until I get a chance to go into the engine. I've heard that Gunk Valve Medic sometimes works since it's a solvent. Anyone here actually try it? Or any others?
Thanks!
Re: Any sticky valve additives actually work? [Re: polkat] #59449
05/19/08 01:43 AM
05/19/08 01:43 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
put a pint of trany fluid in crank case and a few ounces in a tank of gas and if it is a dirt prob it should get disolved !
Re: Any sticky valve additives actually work? [Re: calrobb2000] #59450
05/19/08 03:49 AM
05/19/08 03:49 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
marvel mystery oil
I am truckless..
Re: Any sticky valve additives actually work? [Re: 340SHORTY] #59451
05/19/08 07:13 AM
05/19/08 07:13 AM
Sea foam
Re: Any sticky valve additives actually work? [Re: calrobb2000] #59452
05/19/08 07:24 AM
05/19/08 07:24 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
hi
I agree - Just before an oil change add a quart of ATF to the oil and run for a few miles and then dump the oil and filter. It will do as much as any additive on the market. even if it overfills the crankcase for that few miles won't hurt anything. Just don't pound on it.
Re: Any sticky valve additives actually work? [Re: MoparforLife] #59453
05/19/08 12:37 PM
05/19/08 12:37 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
hi
And I also agree but if you are hearing a ticking lifter I really doubt if anything but an actual repair will help your noise. -Bob
