Re: Automatic shifters?
[Re: rattler]
#594280
01/26/10 06:15 PM
01/26/10 06:15 PM
Posts: 251 Lithonia, Ga
36PLYM
Lithonia, Ga
I used Lokar on the 36. Have a 518 trans. Seem to have good adaptability to unique situations.
36 Plymouth Coupe 318 w/360 heads 518 trans 8 3/4 rear Ga. Tech BCE'78
[Re: 36PLYM]
#594282
01/26/10 11:23 PM
01/26/10 11:23 PM
Posts: 773 Crofton, Ky.
rattler
Crofton, Ky.
I may end up modifying one to look like a standard shift, not sure yet. One problem with the normal aftermarket shifters is thier height. It will need to be tall enough for a truck. Randy
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
[Re: rattler]
#594283
01/29/10 04:47 PM
01/29/10 04:47 PM
Posts: 1,757 levittown pa
fstfish66
levittown pa
i have a lokrap in my rod,,in my experience it doesnt seem to adapt well to a 904,,as far as the built in nutrel safty switch,,it doesnt work properly in all positions,,but they do have several length arms to choose from,,,gennie shifters were first lokrap stole there gate design and added a button to the shifter,,,,
i also wanted to put a push button in my rod,,but the cost to adapt a push button tranny to except a modern lock up converter wasnt worth it in my eyes,,,imperial services makes a push button adapter for non push buton trannys,, but ive \heard its expensive,,
1966 barracuda prostreeter super charged 340(SOLD) 1940 dodge coupe 241 hemi street rod 2014 ram express hemi 4x4 dailey driver 2015 cherokee 2013 R/T classic
[Re: rattler]
#594284
01/29/10 04:47 PM
01/29/10 04:47 PM
Posts: 1,722 Chicagoland
Cooter
Chicagoland
Then definitely get the Lokar. Had a Gennie in my Trailduster, and loved it. The Lokar has a pushbutton that my Gennie didn't.
Whenever I am online I am totally naked.
(Under my clothes)
[Re: Cooter]
#594285
01/29/10 08:27 PM
01/29/10 08:27 PM
rattler
Crofton, Ky.
I have a catalog on the way from Gennie. I liked the looks of stuff on thier web site and didn't want a button on the shifter.Randy
[Re: rattler]
#594287
03/07/10 10:51 PM
03/07/10 10:51 PM
Posts: 15,487 Florida
scratchnfotraction
yep,i am looking at the comander shifter myself and just got the top hat skull air clear hold down very cool lot of handles to choise from also the floor mount lokar gets a looky see also as i might not have the clearance on top of the tranz for the shifter to mount correctly
[Re: scratchnfotraction]
#594288
03/16/10 10:01 PM
03/16/10 10:01 PM
Posts: 163 Iowa,US
4bbl
Iowa,US
I am using the column out of the 85 150 on the 50 rod, including column shifter. had to shorten it three or four times to retain all switches and shifter. Not fun but time was cheep, after market parts were not.
4bbl
If you can't hear it coming what's the point.......
[Re: 4bbl]
#594289
03/16/10 11:03 PM
03/16/10 11:03 PM
fstfish66
levittown pa
kool man,,modifing is hot rodding,,,we dont always have to buy it,,,nothing wrong with making it,,,,,,pics please
[Re: rattler]
#594291
03/17/10 11:20 PM
03/17/10 11:20 PM
fstfish66
levittown pa
building and custom one off is kool,,,,the throw just seems longer,,because you made the handle longer,,,,grab it as low as you can and shift it,,you will see that the throw seems shorter,,,,pics please
[Re: fstfish66]
#594296
03/22/10 09:23 AM
03/22/10 09:23 AM
rattler
Crofton, Ky.
No, the tail housing on this trany was set up for a two piece slider driveshaft like a 4-wheel drive use's.The forward u-joint bolted to the trany with straps the same as the rear.
[Re: rattler]
#594297
03/22/10 09:44 PM
03/22/10 09:44 PM
rattler
Crofton, Ky.
Here are some pics, i hope.
