Re: any to dip a hood in paint to coat inside of bracing?
[Re: dirt]
#594257
01/26/10 04:41 PM
01/26/10 04:41 PM
Posts: 15,487 Florida
scratchnfotraction
ospho maybe??? rust bullet??? por 15??? use a spray and shoot it in between the brace and sheet metal,may need to drill a hole and plug it like they do when the rust proof a car in the doors and rockers ect... I have only heard of acid dipping the hole body to remove the wieght on those 68 hemi Dart/Cudas but then they would wrinkle the 1/4 panels with super torque hole shots after a while that would be a big tank to dip a hood or a whole car body
[Re: shadowauto]
#594265
01/28/10 05:03 PM
01/28/10 05:03 PM
Posts: 7,497 Austin, TX
HemiDave
Austin, TX
Hi I had 4 charger buldge hood (air grabber) acid dip I was it good I epoxie the best I could six months later I had stain coming out from the seam I drill all the spot and split them every seam had major rust specialy at rear so I send all those hood back to the acid dip each hood in 2 pieces now I am not woeey anymore do it twice do it right the last two hood I send to the acid tand are 71-72 runner hood they acid dip they wash it and ecoat just like factory with electricity one hood has been painted about a year ago and in storage not sure if it started to leak yet time will tell but the charger bulde I am sure they will not rust again cheaper to buy a new repo but it not original up to you Francis 905-714-1101
Punctuation, eh?
