Removing Block Drain Plugs? #59393
05/18/08 10:36 PM
05/18/08 10:36 PM
Anonymous OP
Anonymous OP
Hello,
I have read several places that it's a good idea to remove the block's drain plugs when flushing the cooling system. I have not attempted this step when doing a flush of the system before, but wanted to give it a shot next time.
My question is -- Is it really safe to go ahead and remove these plugs? Is there a possibility of damaging or stripping the plug or worse yet, the block threads? Do they come out easily or are they generally stuck in there from years of heating up the block?
Would be interested to hear others experience with this and any potential gotchas that might make this too risky to try.
Thanks very much!
Re: Removing Block Drain Plugs? #59394
05/18/08 11:28 PM
05/18/08 11:28 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I always take them out, but they can be super stubborn. The ones that won't turn out I let the machine shop tackle.
Re: Removing Block Drain Plugs? [Re: Neil] #59395
05/18/08 11:32 PM
05/18/08 11:32 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Once they're out, on non-#s restorations I like to put petcocks in there with drain hoses on them; makes it easier to service the cooling system.
Re: Removing Block Drain Plugs? [Re: topside] #59396
05/18/08 11:35 PM
05/18/08 11:35 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I agree.
I was going to just that on my last engine, but my block hugger headers are right in front of the drain holes so there was no room for the drain valves.
Re: Removing Block Drain Plugs? [Re: Neil] #59397
05/18/08 11:46 PM
05/18/08 11:46 PM
A collage of whims
A collage of whims
Neil, maybe you could put a 45* or 90* fitting into the block to get clearance...
Re: Removing Block Drain Plugs? [Re: Neil] #59398
05/19/08 01:17 PM
05/19/08 01:17 PM
Anonymous OP
Anonymous OP
When putting these plugs back in, is it recommended to coat the threads with something to make a better seal? Or is it best to just put back in as-is?
Also, about how tight would you put these plugs back in ?
Thanks!
Re: Removing Block Drain Plugs? #59399
05/19/08 01:28 PM
05/19/08 01:28 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
use thread sealer , its a pipe plug , tapered thereads , you'll know when its in far enough
Re: Removing Block Drain Plugs? #59400
05/19/08 01:29 PM
05/19/08 01:29 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
You can put plumbers tape on the threads and just snug them in. Not need to smoke them down.
