Rotella T users - zinc? #59379
05/18/08 10:13 PM
05/18/08 10:13 PM
the left coast
Hank Offline OP
Hank  Offline OP
the left coast
I've been using Rotella T diesel oil for several years now per recommendations on this board. I went to change the oil today and realized I was out. So down to the parts store and they were out, too. Then I remembered this post on Hemmings a few months back and decided to hold off til next weekend til I asked here.
http://blog.hemmings.com/index.php/2007/12/07/hmx-countdown-to-ignition-t-minus/
This bottle of Rotella T was rated CJ-4, which is the latest (as of 2007) specification for diesel oils and follows the spark engine oil trend of low zinc content. Only diesel oils rated CI-4 or earlier (CH-4, CG-4, etc.) have the proper zinc content. As for spark engine oils, look for an API rating of SE or earlier (SD, SC, etc.) for the proper zinc content. Don’t do what I did and buy diesel oil expecting it to have enough zinc for your engine break-in.
So have they changed the formula? Do I need zinc in my old 361? (which has never been rebuilt to my knowledge.) Any better oil out there than Rotella T? Thanks.
Re: Rotella T users - zinc? [Re: Hank] #59380
05/18/08 10:22 PM
05/18/08 10:22 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
I don't feel that it is nessessary in older flat tappet cam engines that are relatively stock with not very high valve spring rates.
Re: Rotella T users - zinc? [Re: Hank] #59381
05/18/08 10:51 PM
05/18/08 10:51 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
Will this subject every get ironed out for the masses?
Get yourself some Delo 400 LE 15W40. NAPA's house brand 15W40 "diesel" oil, or Valvoline's 15W40 diesel oil is good. They are all CJ-4 with plenty of zinc (1300 plus ppm) for stock to mild builds. In fact, many of the racers run the 15W40 diesel oils. Plenty of zppd (zinc) for ya, at least 1300 ppm.
The synthetic diesel (also called heavy duty engine oil HDEO) has more zinc than the dino oils.
Shell Rotella T 15W40 has just under 1200 ppm zinc. Shell Rotella T 5W40 synthetic has over 1300 ppm zinc.
Do a search. This subject has been covered real well.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: Rotella T users - zinc? [Re: Junky] #59382
05/18/08 10:59 PM
05/18/08 10:59 PM
Ft Worth,Tx
71mopar383 Offline
super street
71mopar383  Offline
super street
Ft Worth,Tx
Can you break in a new cam with 15w40?
71 Charger
Re: Rotella T users - zinc? [Re: 71mopar383] #59383
05/18/08 11:42 PM
05/18/08 11:42 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
When breaking in a new cam I always use EOS or whatever high-zinc cam break-in lube (Comp sells some, for example) teh cam manufacturer calls for. If I was running a flat-tappet cam with a lot of spring pressure, I'd want to break it in with weaker springs then swap in the stiff ones. A cam with wiped lobes is an expensive pain in the butt compared to using a little caution; OK, call it paranoia!
Re: Rotella T users - zinc? [Re: Junky] #59384
05/18/08 11:48 PM
05/18/08 11:48 PM
not likely.. thats all i'm gonna say.
Re: Rotella T users - zinc? #59385
05/18/08 11:50 PM
05/18/08 11:50 PM
the left coast
Hank Offline OP
Hank  Offline OP
the left coast
Sorry guys. I hang out in General so much I forgot you could actually search archives. Thanks for the info. Much appreciated.
Re: Rotella T users - zinc? #59386
05/18/08 11:51 PM
05/18/08 11:51 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
I'm afraid you're right.
Re: Rotella T users - zinc? [Re: Junky] #59387
05/19/08 12:15 AM
05/19/08 12:15 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
Here's a delo 400 LE oil analysis, 1300 PPM zinc.
http://www.ford-trucks.com/forums/606026-virgin-delo-400-analysis.html
Re: Rotella T users - zinc? [Re: Hank] #59388
05/19/08 06:32 AM
05/19/08 06:32 AM
Montana
FuryUs Offline
FuryUs  Offline
Montana
I think the zinc is more important for new flat tappet break-ins than for older engines. A 20 to 40 year old engine that's been well-maintained has an established wear pattern on the cam and lifters and is probably safe with reduced zinc levels.
Re: Rotella T users - zinc? [Re: FuryUs] #59389
05/19/08 09:57 AM
05/19/08 09:57 AM
dogdays Offline
dogdays  Offline
There is a world of difference between the stock cam lobes and springs of the flat-tappet era and the ultra-high acceleration lobes and big springs of today. Even the 30-year-old "chevy lobes" found on many high performance cams of the 70s were really mild in comparison.
So you have to be really careful breaking in a new high intensity cam.
One thing that always makes me wonder, it is easy to say use weaker springs but where do you get weaker springs for a 0.545" lift camshaft?
R.
Re: Rotella T users - zinc? [Re: dogdays] #59390
05/19/08 12:24 PM
05/19/08 12:24 PM
Simi Valley, CA
MoparJ Offline
MoparJ  Offline
Simi Valley, CA
I agree. I use Delo 15w40 in everything I have. Not only that, I get a discount from my dad's construction business if I go to the diesil fuel stations.
One of my 318s now has 6000 miles since rebuild with a Comp XE268 cam. Can I discontinue use of the Comp break in lube and just use the oil? If I could save $13 dollars an oil change and still be safe?
Dont mean to hijack, but maybe it could help others out if they search the same thing in the future.
2016 Ram 1500 Crew Cab: 5.7, 65RFE, 4.56 gears with locker, Hemifever tuned, AFE intake, 87mm throttle body, JBA headers, 3" Flowmaster exhaust, split to dual 2.5" exits. 13.57 best ET so far.
Searching for new A or B Body Project!
Re: Rotella T users - zinc? [Re: MoparJ] #59391
05/19/08 01:31 PM
05/19/08 01:31 PM
Ft Worth,Tx
71mopar383 Offline
super street
71mopar383  Offline
super street
Ft Worth,Tx
i've always thought you used 30w on the 1st start up and 20min break in.
71 Charger
Re: Rotella T users - zinc? [Re: 71mopar383] #59392
05/19/08 01:37 PM
05/19/08 01:37 PM
Simi Valley, CA
MoparJ Offline
MoparJ  Offline
Simi Valley, CA
With the lack of zddp (zinc)in today's oils, it is not wise with the new flat tappet performance cams out on the market. You need to use some kind of a break in lube that adds those addititives, such as GM EOS, COMP cams break in lube, Hughes engines lube in conjunction with a good oil. Without the sufficient level of zinc in the oil during break in, the proper cam wear pattern may not be achieved, thus leading to premature cam lobe failure.
Stock motors with NOS cams may not be as vulnerable to this as new aftermarket cams subject to high spring pressure are.
-Justin
