Page 1 of 4 1 2 3 4
69 383 H code some w holley carb some carter AVS why? #593769
01/25/10 06:07 PM
01/25/10 06:07 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
my 69 383 H code.. for dan.. [there better now?] has a holley while some have an avs whats the difference and why did they do this? dan
Re: 69 383 HP some w holley carb some carter AVS why? [Re: ph23vo] #593770
01/25/10 06:24 PM
01/25/10 06:24 PM
San Antonio, TX
CurYellowBird Offline
San Antonio, TX
I did a lot of asking about this topic a couple months back. I have a 71' 383 HP and it has a carter on it.
One issue was that there was a quality issue with holley back in the late 60's and early 70's. For some reason, can't remember what part specifically, but the carb over time would start leaking gas and was a hazard to causing car fires. The replacement from the dealers was the carter carb after chrysler realized the issue.
Another thing is whether your car has AC or not. I've looked at 440's and 383's and why they both had either holley or carter. Mine has a carter because it has AC so I'm guessing the body of the holley carb interfered with our massive AC compressors. I had a few guys tell me my car came with a holley, which is a possibility but from what I found it came with a carter.
Project War Bird: 1971 Plymouth Roadrunner 383 4 speed with air conditioning GY3 Curious yellow All original
Re: 69 383 HP some w holley carb some carter AVS why? [Re: CurYellowBird] #593771
01/25/10 06:52 PM
01/25/10 06:52 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
I bought a 70 383 4 spd cuda off the showroom in 1970 & it had AC and the Holley 735 CFM carb. I remember cause I pulled the AC out, installed a foam air cleaner, cut the scoops open in the hood & installed headers. Wonder if meeting smog requiremants was a factor between the Carter or Holley?
Re: 69 383 HP some w holley carb some carter AVS why? [Re: ph23vo] #593772
01/25/10 09:18 PM
01/25/10 09:18 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
my 69 383 hP has a holley while some have an avs whats the difference and why did they do this? dan
Generally the 335 horse cars got the Carter and the 330 horse cars with automatic (i.e. RR/SB with A/C) got a Holley.
What's your application?
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: 69 383 HP some w holley carb some carter AVS why? [Re: 69CoronetRT] #593773
01/25/10 09:30 PM
01/25/10 09:30 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
69 fury VIP 383 HP A/C loaded options car including W23 recall wheels! dan
Re: 69 383 HP some w holley carb some carter AVS why? [Re: ph23vo] #593774
01/25/10 09:34 PM
01/25/10 09:34 PM
Royersford, PA
bschargerse Offline
bschargerse  Offline
Royersford, PA
My '69 Charger 330-horse 383 has a Carter AVS.
Brian - 1971 Dodge Challenger
"The Dodge, which was practically stock, just left the Mustang like you wouldn't believe."
Re: 69 383 HP some w holley carb some carter AVS why? [Re: bschargerse] #593775
01/25/10 10:01 PM
01/25/10 10:01 PM
New Zealand
nz383man Offline
nz383man  Offline
New Zealand
My '70 Barracuda 330-horse 383 auto, non air has a Carter AVS.
Re: 69 383 HP some w holley carb some carter AVS why? [Re: ph23vo] #593776
01/25/10 10:13 PM
01/25/10 10:13 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
Wasn't it a A/C C body thing in 69? When my uncle gets back in town I will have to see if I can jog his memory on that one we parted way back when to see what carb it had. I don't seem to remember
I got one lug for ya
Re: 69 383 HP some w holley carb some carter AVS why? [Re: rrunner] #593777
01/25/10 10:22 PM
01/25/10 10:22 PM
Hightstown, NJ
njdevil2 Offline
njdevil2  Offline
Hightstown, NJ
'70 roadrunner convertible 383/4speed, 8/1969 build date Edelbrock aluminum intake with.....a HOLLEY.
So, now do we throw away the book (again?) No A/C car for sure...and that's what came with the car. Early production with left over '69 parts? It's just too weird.
1970 road runner Convertible
1 of 179
Re: 69 383 HP some w holley carb some carter AVS why? [Re: njdevil2] #593778
01/25/10 10:29 PM
01/25/10 10:29 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
LP=Holley
HP=Carter
I did part a 72 C-body that was LP but had a carter that was date coded to engine, maybe somebody changed it or a factory glitch.
Mitch
Re: 69 383 HP some w holley carb some carter AVS why? [Re: 500ciDuster] #593779
01/25/10 11:08 PM
01/25/10 11:08 PM
Abilene, Texas
fastmark Online content
fastmark  Online Content
Abilene, Texas
I had a 70 Cuda 383 3 speed no air with a Holley 335 hp. My 70 Challenger 383 auto,330 horse, air has a Carter. I am not sure what reasons they had for installing a carb for a particular engine. I have a 69 NYer with a factory Holley and a 440 in a 350 horse motor. Go figure. The 440 hps in 69 and 70 had Carters.
Re: 69 383 HP some w holley carb some carter AVS why? [Re: fastmark] #593780
01/26/10 02:59 AM
01/26/10 02:59 AM
Seattle, WA
rss Offline
rss  Offline
Seattle, WA
I believe that in 70 most 383 HPs came with Holleys. Don't know about other years.
Re: 69 383 HP some w holley carb some carter AVS why? [Re: rss] #593781
01/26/10 04:43 PM
01/26/10 04:43 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
The year makes all the difference in the world!
1968 383 4bbl 330hp AVS
1968 383HP 4bbl 335hp AVS
1969 383 4bbl 330hp Holley
1969 383HP 4bbl 335hp AVS
1970 383 4bbl 330hp AVS
1970 383HP 4bbl 335hp Holley
NO 383HP (335hp) c-bodies!!
Re: 69 383 HP some w holley carb some carter AVS why? [Re: Triggerfish] #593782
01/26/10 04:47 PM
01/26/10 04:47 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
NONE of the factory MOPAR single 4bbl HOLLEYs were 735cfm.
I believe the 4160 series HOLLEYS MOPAR used are 600cfm.
Re: 69 383 HP some w holley carb some carter AVS why? [Re: rss] #593783
01/26/10 06:26 PM
01/26/10 06:26 PM
Ohio
john55 Offline
john55  Offline
Ohio
I had a '70 roadrunner 383 auto, it also had a Holley, and it was original
The Plymouth Win You Over Beat Goes On
Re: 69 383 HP some w holley carb some carter AVS why? [Re: john55] #593784
01/26/10 07:21 PM
01/26/10 07:21 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
That's not a 69 though.
Re: 69 383 HP some w holley carb some carter AVS why? [Re: 6bblgt] #593785
01/27/10 02:07 AM
01/27/10 02:07 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Except for real Mopars (383 A-Bodies) which all had 330 horsepower HP engines with Carters only in 69. ALL 383 HP A-Bodies had Carters.
JB Rhinehart, Realist
A-Body's RULE!
Re: 69 383 HP some w holley carb some carter AVS why? [Re: 6bblgt] #593786
01/27/10 02:30 AM
01/27/10 02:30 AM
Seattle, WA
rss Offline
rss  Offline
Seattle, WA
I don't doubt this, but sure seems strange that they would do one thing in 69 and then the exact opposite thing in 70. Ma Mopar always leaves you guessing
Re: 69 383 HP some w holley carb some carter AVS why? [Re: 6bblgt] #593787
08/26/10 11:31 PM
08/26/10 11:31 PM
Missouri
P
Promopar Offline
Promopar  Offline
P
Missouri
I was told that the 69' road runner auto a/c 330hp used the Carter 4638.
Is this wrong?
Re: 69 383 HP some w holley carb some carter AVS why? [Re: Promopar] #593788
08/28/10 01:25 PM
08/28/10 01:25 PM
Hiram, Georgia
474218 Offline
474218  Offline
Hiram, Georgia
Is this wrong?
Yes the AVS-4638S was used on the 330 hp engines.
The 1969 Shop Manual lists the following carburetors and the engine/transmision:
I added the horsepower ratings obtained from several different sourcec.
AVS-4615S 383/manual/330
AVS-4616S 383/automatic/330
AVS-4638S 383/automatic/330
AVS-4711S 383/manual/335
AVS-4682S 383/automatic/335
AVS-4617S 440/manual/375
AVS-4616S 440/automatic/375
AVS-4640S 440/automatic/375
Holly R4166A 440/automatic/350
It lists no 383/Holly combination.
Page 1 of 4 1 2 3 4
