Re: Simple /6 fit question
[Re: Rug_Trucker]
#593707
01/25/10 06:56 PM
01/25/10 06:56 PM
Posts: 20,201 Park Forest, IL
slantzilla
Park Forest, IL
You will have to use the '62 motor mounts, carburetor, intake manifold, pan, and pickup tube, the '67 stuff is way different.
You can use the '67 intake and carb if you switch over to a cable throttle, '62 probably has rod style linkage.
You may need to find a driveshaft too. The '62 was ball & trunnion.
[Re: scratchnfotraction]
#593709
01/25/10 09:54 PM
01/25/10 09:54 PM
Since the 62 Valiant owner doesn't have the original engine, let me just point out that any 1966 and earlier carbs, mounts, and oil pans will work, not just 62.
62-6 chassis/suspensions are dimensionally the same. 61-earlier fronts are different; as are 67-later.
[Re: calrobb2000]
#593711
01/25/10 11:46 PM
01/25/10 11:46 PM
hi better check cranck for fit of convertor if auto as i recall there was a pilot snout dia change someware from early to late ?
1. The Valiant owner planned to swap the 67 engine and trans into the 62, so the crank/converter fit wouldn't be an issue anyway;
2. The change occurred in the 68 model year. A 67 slant-6 engine will bolt up to a 62 slant-6 trans/converter w/o a problem.
