Enclosed trailer guys what generator?
#593517
01/25/10 02:03 PM
01/25/10 02:03 PM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
We are looking around at maybe getting a enclosed trailer soon and I was wondering what size generators are you guys using. Looking to get a quiet one that will run lights, a/c or heater, battery chargers, air compressor. Currently have a 2500 Yamaha that is great but it has problems running just a battery charger and air compressor.
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: Enclosed trailer guys what generator?
[Re: B1KILLER]
#593522
01/25/10 02:31 PM
01/25/10 02:31 PM
Posts: 7,498 Minnesota
Hemi_Joel
Minnesota
This may not be the route that everyone else wants to take, but I got a 4000 watt Onan out of an older motorhome. It is 1800 rpm and extreemly quiet. I got it free by buying a dirty old motor home that would barely run for dirt cheap. Gave it a really good bath, put new plug wires on it, took the generator for myself, and sold the motorhome at a nice profit. Worked for me.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#593523
01/25/10 02:59 PM
01/25/10 02:59 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I have the same one... Onan 4000... it runs my AC/heater, lights and compressor with no problems
[Re: MR_P_BODY]
#593525
01/25/10 03:19 PM
01/25/10 03:19 PM
Jacob Pitt
Mansfield, Tx
Thanks guys. The main reason I want a quiet one is for multi-day races, instead of getting a hotel I'm just going to sleep in the trailer and I don't want a chainsaw going all night. But I want one that I know will run the things I need while racing too.
[Re: Jacob Pitt]
#593526
01/25/10 03:20 PM
01/25/10 03:20 PM
Posts: 43,286 Bend,OR USA
Cab_Burge
I have a older Yamaha 5500 watt 110/220 construction generator mounted on the tongue of my Pace car trailer, it is NOISY, but it works well It has the fuel saver feature, idles until something is turn on or is activated and it is electric start the Honda inverters are a lot quieter though. My motorhome had 4000 watt generator(not a Onan or Generac, it was a Kohler) that would run the air conditioning and everything else at night and never failed us once Lots of option out there Check on line first for new ones and Craigs list for used ones
[Re: Jacob Pitt]
#593527
01/25/10 06:47 PM
01/25/10 06:47 PM
Posts: 2,118 Byron, NY
W.I.N. Racing
Byron, NY
I'd go Onan, I have an Onan 6300 (motorhome gen) that is quiet runs 1800 RPM but I swaped it out for a 4000 Honda liquid Cooled(motorhome gen), runs at 3600 rpm ...rather have the onan, definitly quieter and more fuel efficient. plus less mantainance
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: MegaDart]
#593530
01/25/10 07:49 PM
01/25/10 07:49 PM
Posts: 892 Caledonia, Ohio
BigDog68Dart
Caledonia, Ohio
3000EU
same as the big dog use's I normally ask my neighbors at the track to plug into us, to keep the noise down, no problems and very good on fuel! 4 stars! around 1300 bucks new for mine
[Re: 68roadrunner]
#593531
01/25/10 07:54 PM
01/25/10 07:54 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
The Hz. ( frequency or cycles ) is entirely contingent on r.p.m. , so if you want to run delicate electronics ( T.V. or computer ) you want one with enough power to not lug down as the load increases. Figure out your max. electrical load in Watts and multiply by 1.5. This will give you a baseline for the kw rating you want. The differences in r.p.m. given above are due to a different winding in the gen set itself and probably have to do with power characteristics of the power plant. Diesels are optimum for a lot of reasons except cost.........they are a heck of a lot more money. I like the Honda's because they are extremely quiet , but I know Onan makes very nice units too. I have a loud , obnoxious one that my Dad gave me , but have worked on these filthy buggers quite a bit..........mostly bigg'uns.
[Re: 340Cuda]
#593533
01/25/10 10:56 PM
01/25/10 10:56 PM
W.I.N. Racing
Byron, NY
If you want one you can run with out opening the generator door you will need a motor home style generator like mentioned above.
Good point. Either of mine I just hit the remote start switch from inside the trailer and good to go....Still like the Onan better
[Re: '72CudaRacer]
#593535
01/26/10 01:10 AM
01/26/10 01:10 AM
Posts: 19,382 Las Vegas
Al_Alguire
Las Vegas
Another 3000EU Honda here. Never any issues with enough power.
