3.23 sure grip- pros and cons
#593385
01/25/10 04:44 AM
01/25/10 04:44 AM
Posts: 583 San Antonio, TX
CurYellowBird
San Antonio, TX
I'm going to be keeping at stock to slightly over stock build on my 383 backed by a 4 speed. I'll be getting an aluminum intake to lighten up the front from that iron brick of a factory intake, a slightly larger cam for a little more power, and possibly headers...still undecided.
Is anyone using 3.23's and are they great cruising gear with still plenty of pep to get up and go? Or is it worth a few extra rpm and bump up to a 3.55 or 3.91. Mind you that I'm using the #'s drivetrain and won't be racing or bashing on it a whole lot. Just the occasional show off.
Project War Bird:
1971 Plymouth Roadrunner
383 4 speed with air conditioning
GY3 Curious yellow
All original
Re: 3.23 sure grip- pros and cons
[Re: dOc !]
#593387
01/25/10 04:59 AM
01/25/10 04:59 AM
CurYellowBird
San Antonio, TX
With a 4 speed a 2.76 might be just a little too high for me. With that gear I could probably go over 200mph . Me and my old man were discussing an issue last night. I had already bought a 440 out of that 78 winnebago I told you about Doc a couple months back. Well he suggested that its probably better leaving the car with what it came with. He made his Dart into such a monster with his 440 that he is having a hard time just cruising in it. So I have a feeling the 383 is gonna suit my needs as a cruiser and keep that origional factor.
Project War Bird:
GY3 Curious yellow
All original
[Re: dOc !]
#593389
01/26/10 02:19 AM
01/26/10 02:19 AM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
3:23 is well suited for the short stroke higher winding 383 engine. With the 4 speed you will be very happy. I am running a 323 in my 68 Charger (440 )with some 275 60 15 tires and it is a little buzzy at 70..., but I am now used to every thing that is on the road having overdrive and spinning under 2 grand at 70...
[Re: sthemi]
#593390
01/26/10 09:13 AM
01/26/10 09:13 AM
Posts: 15,487 Florida
scratchnfotraction
3.23sg run it in my sb stepside and does fine on the road as a cruzer will still run on the interstate at speed and will still come out the hole showing off for playing and show boating I pop the 3.91sg in the 8 3/4 housing then it dont go on the interstate and it comes out the hole like a bat out of hell drops the mpgs a bunch also for long trips I have a 2.76 I pop in did I mention thats why I run an 8 3/4 in my stepside??? and its an A-body housing in the 85 truck to boot
[Re: dOc !]
#593392
01/26/10 10:37 AM
01/26/10 10:37 AM
Posts: 1,565 tennessee
pushbutton
tennessee
A 3.23 is a decent all-around gear ...I would just use whatcha' got.
[Re: pushbutton]
#593393
01/26/10 01:22 PM
01/26/10 01:22 PM
Posts: 12,422 Kalispell Mt.
HotRodDave
Kalispell Mt.
I had 3.23s in a valiant with a 360 and hated going on a trip with them if I could go over 50 mph. It just felt like I was stuck in 2nd gear.
I have a 2.76 SG in my cuda now and love them, I can buzz along at 80 and barely work up a sweat and the 235-55-17s can barey hook with the 360 in it as is so a lower gear would do me no good.
[Re: CurYellowBird]
#593394
01/26/10 04:07 PM
01/26/10 04:07 PM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
Ok, first think 3.23 with SG came out in that way from dealer, so is definitelly a good all around setup. Nothing wrong with those...3.55 was option too even on R/Ts
not everything requires more than that, although the mods you are planning
[Re: can.al]
#593396
01/26/10 07:50 PM
01/26/10 07:50 PM
CurYellowBird
San Antonio, TX
I'm gonna shoot comp cams a request. The one I'm looking at, since my goal is mainly torque and not a high rpm screamer, is the XE262. Hopefully it will give me the power I want and still sound good since it does have a 110 centerline.
I'm not sure if the XE262 will utilize our large tappet diameter or not.
Project War Bird:
GY3 Curious yellow
All original
[Re: CurYellowBird]
#593397
01/26/10 08:06 PM
01/26/10 08:06 PM
pushbutton
tennessee
I'd go with the XE268.
[Re: 69rrgrabber]
#593400
01/27/10 01:25 AM
01/27/10 01:25 AM
CurYellowBird
San Antonio, TX
I want to build a torque monster rather than a high rpm car. That's why I opted for the XE262 but if there's better let me know.
I'm probably going to get an aftermarket dual plane intake and a pair of summit headers. I'll put the lead brick intake and manifolds on the side. I want to keep the motor stock looking. The headers will be the only thing and even then most people will accept headers.
Project War Bird:
GY3 Curious yellow
All original
[Re: CurYellowBird]
#593401
01/27/10 09:31 AM
01/27/10 09:31 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
lunati voodoo 60302 is what I'd use then....the XE (non HL) lobes from comp are their most aggressive .842" lifter lobes (chevy lifter diameters). their good, I had an XE262 in my 360 and liked it. the voodoos though were designed by the same guy who designed the ultradyne cams, and the chrysler cams are designed for a .904" lifter. gets you a tad more .050 dur, more .2" dur, and more lift for a given advertised dur.
[Re: patrick]
#593402
01/27/10 10:57 AM
01/27/10 10:57 AM
HotRodDave
Kalispell Mt.
I have the XE268 in my 360 in my car and the gearing is not a problem. I would have prefered the XE262 but I just used what I had.
[Re: Junky]
#593404
01/27/10 01:41 PM
01/27/10 01:41 PM
CurYellowBird
San Antonio, TX
The good thing is I don't have to worry about a torque converter and I have manual brakes so vacuum won't be an issue. I just have to learn how to take advantage of the 4 speed, I'm used to driving automatic muscle so this is kinda new to me. Lots of older guys telling me it will be a load of fun.
Junky, Are you using an aftermarket intake, heads, and headers? Do you have pics of your engine?
Project War Bird:
GY3 Curious yellow
All original
