Rebuilt 340
#592615
01/24/10 11:57 AM
01/24/10 11:57 AM
70duster340
The rebuilder said that I should at least manually turn the engine over every month or so. Since it's on a makeshift stand awaiting installation into the Duster, and the weather has not been cooperating lately, is there some way that I can safely store it and not have to monthly turn the engine over? It's a 71 340, bored .030 over, with Eddy heads and SRP flat top pistons, with an advised CR of 9.9 to 1. I have it currently stored in an engine bag. Thanks much for any suggestions!
Re: Rebuilt 340
[Re: 70duster340]
#592618
01/24/10 12:24 PM
01/24/10 12:24 PM
RapidRobert
I'm assuming you have the rocker shafts unbolted to take the load off of the springs? An option would be to bag it w the late Billy Mays's "space bags" www.spacebags.com then you draw all the air out w a vacuuum cleaner nozzle and I'd add some bags of dessicant to absorb the remaining (or most of it) moisture. then it'd be like the inside of the pyramids and wouldn't need to be rotated occaisonally and on that note I'd spray the cyl walls liberally w something thick & then imnho it wouldn't need to be turned over
Re: Rebuilt 340
[Re: RapidRobert]
#592619
01/24/10 12:37 PM
01/24/10 12:37 PM
70duster340
Nope, didn't unbolt the rocker shafts. Didn't even consider that, Robert! Would fogging the cylinders like you do on a marine engine work? Do those space bags come that large? I had a very difficult time just getting the engine bag closed over the assembled engine. Also, where do you get those dessicant bags?
Re: Rebuilt 340
[Re: 70duster340]
#592620
01/24/10 01:55 PM
01/24/10 01:55 PM
RapidRobert
I would think that he would have coated everything well since I am assuming that he was aware that it was going into long term storage for an extended period of time. I'm not thinking that turning the eng over is going to do much as far as keeping things coated(ex the cyls which are critical) but I would for sure loosen the center rocker shaft bolt 1/4 turn then the next one to the right 1/4 turn then the one on the left side of the center bolt 1/4 turn then the far right one 1/4 turn then the far left one 1/4 turn & repeat until all the pressure if off of all of them. Not sure if space bags are available that large and who has the dessicant bags but they (the dessicant pkgs) are available somewhere. I dont have the last word on storing engines/keeping them from rusting but k.i.s.s. I think I'd oil the cyls, seal the bag w some dessicant bags inside. I do know it's the temp changes that drop the part below the dew point is when moisture condenses and sealing the bag does trap the current amt of moisture that's inside there but that's a lesser evil that it open. I sure dont have the last word on this just thinking out loud here. If he coated EVERY surface I'd feel better.
Re: Rebuilt 340
[Re: RapidRobert]
#592621
01/24/10 02:05 PM
01/24/10 02:05 PM
70duster340
Well Robert, let me give you some history here. The builder is a GM rebuilder, but his son is a friend and set this up. The rebuilder has done one other 340, as a restoration project. Mine had new pistons and rings, new Eddy heads, a HV oil pump, the block hot tanked and bored .030 over, and the rotating assembly balanced. I guess maybe I neglected to advise him that the engine would not be reinstalled immediately, until the day I picked it up. He seemed very worried about the engine needing turned over at least 180 degrees at least monthly. So, my idea was to store it in an engine bag, and seal it up. I never even considered relieving the spring pressure, so I am very glad that I posted here and you replied.
So, the rockers and shafts don't have to be totally removed? Would fogging the cylinders be a viable option? He did run the engine when I got there to show me how well it sounded, so any coating he may have added would most likely me removed now, anyway.
Thanks again very much!!!
Re: Rebuilt 340
[Re: 70duster340]
#592622
01/24/10 02:16 PM
01/24/10 02:16 PM
RapidRobert
Oh OK now I understand, he wanted you to rotate it to oil the cyls because he fired it up to break it in that leaves the cyls pretty much uncoated. I knew I was missing something as I'm sure he's competent (other than the fact of him being a gm type of guy ). Not familiar w the Marine fogging but anyway you can adequately coat the walls with something fairly thick that will stay put then it doesn't need to be turned over. Yes undo the rockers until all valves are close d & can just let the rocker arm assys lay there loose. I'm glad I could help, got a couple of hours before the AFC football game starts EDIT Hearing gm started my blood to boil so I'm gonna test him here, did he drain the oil/filter after he broke it in
Re: Rebuilt 340
[Re: RapidRobert]
#592626
01/24/10 03:01 PM
01/24/10 03:01 PM
Posts: 1,012 indiana
mcmopars
indiana
so what about your car that sits over the winter ?most just change the oil and call it good for 4-5 months,or am i missing something ?
Re: Rebuilt 340
[Re: mcmopars]
#592627
01/24/10 03:11 PM
01/24/10 03:11 PM
RapidRobert
I'm checking that he changed the oil/filter after the 30 minute breakin. With a gm guy you cant assume anything
Re: Rebuilt 340
[Re: 70duster340]
#592632
01/24/10 06:41 PM
01/24/10 06:41 PM
RapidRobert
alot of good choices for oil/additives. Brad Penn oil gets good reports & I think has enough zinc as is and there's hughes' moly breakin lube to pour into your choice of oil and several good combinations. Check the archives & see if any of the prior posts are there that have a ton of good info. Not sure on the weight. I gotta ask with changing the breakin oil being std procedure on a new rebuild breakin & him not doing that is what breakin procedure DID he use. Hopefully 2500 rpm for 20-30 minutes w inner springs removed & I'm a believer in goosing the throttle many times during that time.
Re: Rebuilt 340
[Re: RapidRobert]
#592633
01/24/10 09:37 PM
01/24/10 09:37 PM
70duster340
Unfortunately I wasn't there when he did the break-in run. I guess all I have is his word on that. I had purchased the oil and filter along with the break-in oil additive, so maybe that's why he didn't change the oil after the break-in run. According to him, when the machining was all done, the tolerances were much like a racing engine, which may account for the oil pressure (80 lbs. at idle). This was with the oil cold. Do I need to use a multi-viscosity oil, or just a single weight oil? I live near Summit Racing, so getting my hands on some zinc additive isn't a problem. Also, when installed, the engine will have a dual filter remote oil filter, mounted on the passenger side inner fender. Thanks again for all the tips!!!
Re: Rebuilt 340
[Re: 70duster340]
#592634
01/24/10 09:53 PM
01/24/10 09:53 PM
RapidRobert
Alright hopefully he did it right. I'd think maybe the clear oil was what persuaded him to not change it and the last one I did after breakin man it was dark but I used a ton of black moly paste on the lobes. My knowledge is bad on oil but I think I'd be inclined to go w a straight wt but someone here more knowledgeable may recommend otherwise
