2007 Dakota idle issue #592562
01/24/10 11:44 AM
01/24/10 11:44 AM
70duster340 Offline OP
Every once in a while, while idling, the engine will drop to about 500 rpm's, seem to almost stall, then pick up again. It never stalls, and this symptom only last for a few seconds. I have tried changing the plugs (it needed it, anyway), and have added fuel system cleaner (Seafoam), but to no avail. This is a hit and miss situation, and it never sets a CEL. I have had it to a dealer, but it doesn't happen then, so they tell me they can't help unless the issue duplicates itself.
This a 4.7L HO, 4X4 Quad Cab, with 35,000 miles.
Any help will be greatly appreciated!
Re: 2007 Dakota idle issue [Re: 70duster340] #592563
01/24/10 12:09 PM
01/24/10 12:09 PM
Re: 2007 Dakota idle issue [Re: 70duster340] #592564
01/24/10 01:54 PM
01/24/10 01:54 PM
Anyb
Re: 2007 Dakota idle issue [Re: 70duster340] #592565
01/24/10 01:59 PM
01/24/10 01:59 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
scanned for codes?
Re: 2007 Dakota idle issue [Re: 05dakota] #592566
01/24/10 02:07 PM
01/24/10 02:07 PM
I took it to a dealer when this happened last winter, and there were no codes stored then. So, I assumed that there would be no codes this time, either.
Re: 2007 Dakota idle issue [Re: 70duster340] #592567
01/24/10 02:52 PM
01/24/10 02:52 PM
CHRGR69 Offline
CHRGR69  Offline
IAC?
Grandma always said I had "hands of gold"!
Re: 2007 Dakota idle issue [Re: CHRGR69] #592568
01/24/10 04:54 PM
01/24/10 04:54 PM
Where is that located? Is that the same as the throttle position sensor?
Re: 2007 Dakota idle issue [Re: 70duster340] #592569
01/24/10 06:33 PM
01/24/10 06:33 PM
for the afternoon shift!!!
Re: 2007 Dakota idle issue [Re: 70duster340] #592570
01/24/10 08:39 PM
01/24/10 08:39 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I had some goofy idle problems when I had a weak battery.
Re: 2007 Dakota idle issue [Re: mopars4ever] #592571
01/24/10 08:53 PM
01/24/10 08:53 PM
wisconsin
mod381 Offline
mod381  Offline
wisconsin
A far stretch but possible egr problem?
Re: 2007 Dakota idle issue [Re: mod381] #592572
01/24/10 09:30 PM
01/24/10 09:30 PM
Good advice from you both. Does anybody know where the IAC valve is located? I would like to clean it and see if that helps.
Re: 2007 Dakota idle issue [Re: 70duster340] #592573
01/24/10 10:01 PM
01/24/10 10:01 PM
md
mopars4ever Offline
mopars4ever  Offline
md
throttle body, should be 2 screws to remove IIRC
Re: 2007 Dakota idle issue [Re: mopars4ever] #592574
01/24/10 10:26 PM
01/24/10 10:26 PM
I know I don't know my way around the 4.7L engine, but the only thing I could locate with 2 screws holding it in was the throttle position sensor, which was behind the throttle body. Can anybody offer a pic or something similar to assist???
Re: 2007 Dakota idle issue [Re: 70duster340] #592575
01/24/10 11:39 PM
01/24/10 11:39 PM
Winnipeg, MB
sreinheimer Offline
sreinheimer  Offline
Winnipeg, MB
Should be right under the tps.
69 Dodge Charger - first full resto 05 Dodge Magnum R/T
Re: 2007 Dakota idle issue [Re: sreinheimer] #592576
01/25/10 10:54 AM
01/25/10 10:54 AM
Excellent, that's what I needed!!! Thanks much, sir!
Re: 2007 Dakota idle issue [Re: 70duster340] #592577
01/26/10 11:34 PM
01/26/10 11:34 PM
Columbus, Ohio
wheelsup68dart Offline
Columbus, Ohio
Sometimes the plaque that builds up inside the throttle body itself will cause the IAC counts to go up as well. Not only do you wanna clean the bore for the IAC but also the entire throttle body around the blade and all.
Re: 2007 Dakota idle issue [Re: wheelsup68dart] #592578
01/27/10 08:17 AM
01/27/10 08:17 AM
Thanks for the tip. I did manage to get the IAC valve out. Only 1 screw holding it in, but the rubber seals were really holding that thing in!!! Took a lot of tugging to get it out. Cleaned it up with throttle body cleaner, and cleaned up the throttle body around the butterfly valve, too. Seems to idle much better, but only time will tell about the dropping rpm issue, as it was only a sporadic thing. So far, so good!
