CHALLENGER REAR WINDOW TRIM CLIPS #592502
01/24/10 09:22 AM
01/24/10 09:22 AM
pa
FOXY312 Offline OP
FOXY312  Offline OP
pa
I NEED SOME HELP WITH REAR WINDOW TRIM CLIPS THAT HOLDS THE STAINLESS MOLDING ON FOR 1970 CHALLENGER IF ANY ONE AS PICTURES WHICH WAY ARE THEY MOUNTED TO WINDOW FRAME WHICH IS THE TOP & BOTTOM
Re: CHALLENGER REAR WINDOW TRIM CLIPS [Re: FOXY312] #592503
01/24/10 04:04 PM
01/24/10 04:04 PM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
Hey,
I read your post the first time and I see you revised it. I'm still not sure what you ware wanting to see.
Do you want to see the clips mounted in the frame area of the vehicle or how they attach to the trim itself? Is it spacing you are needing to see? Just trying to see if I can photo what you need or not.
Joe
65 Barracuda
70 Challenger
Re: CHALLENGER REAR WINDOW TRIM CLIPS [Re: jrwoodjoe] #592504
01/24/10 06:56 PM
01/24/10 06:56 PM
pa
FOXY312 Offline OP
FOXY312  Offline OP
pa
THE HOLES ARE ALL DRILLED FROM FACTORY I HAVE NEW METAL CLIPS, WHICH PART OF THE CLIP IS THE TOP THAT THE STAINLESS TRIM MOUNTS TO.
Re: CHALLENGER REAR WINDOW TRIM CLIPS [Re: FOXY312] #592505
01/27/10 10:04 PM
01/27/10 10:04 PM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
Maybe these will help.
Reference 1
65 Barracuda
70 Challenger
Re: CHALLENGER REAR WINDOW TRIM CLIPS [Re: jrwoodjoe] #592506
01/27/10 10:05 PM
01/27/10 10:05 PM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
reference 2
