Re: Dipping and E-coating?
[Re: QuickSilver]
#592267
01/28/10 09:02 PM
01/28/10 09:02 PM
Posts: 182 NW of Indy
Thackdaddy
NW of Indy
Quicksilver,
was this on cars that were just stripped, or stripped and e-coated?
'71 Duster
[Re: ta340]
#592268
01/28/10 10:20 PM
01/28/10 10:20 PM
Posts: 543 Indiana, Just Off I-70
BradD
ta340...If you don't mind, please email me. I'd like to discuss the quality of that ecoat. Brad brad@dornautocraft.com
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
[Re: warmpancakes]
#592269
01/28/10 11:32 PM
01/28/10 11:32 PM
Posts: 17 ohio
ta340
ohio
why did you ecoat with fenders on?
Mayflowers main job is doing semi-cabs. They put your car on their processing line. The car has to be mounted to their fixtures. The more you can have bolted on the car body the better. Car doors can be put on a smaller fixture to be dipped. I shimed the fenders with washers so the ecoat could get in between. The more they have to rig up on the fixtures the more it cost you. When I had mine done, they tried to do one car a month. They scheduled you a day to bring it in at 9:00am and you were done by 3:00pm. I had mine done 2 years ago and have not seen any problems yet.
[Re: chrisf]
#592274
01/29/10 10:58 AM
01/29/10 10:58 AM
Posts: 951 Temperance, MI
prochargedhemi
Temperance, MI
to me it sounds like alot of risk invovled in dipping just to get it a tiny bit cleaner than you could do with a media blaster.
Theres just as much risk media blasting though. The nice thing about dipping is everywhere is clean not just were you can get a nozzle. The biggest problem i see with stripping is getting the acidic stuff all washed out and neutralized.
[Re: chrisf]
#592275
01/31/10 02:36 PM
01/31/10 02:36 PM
Posts: 1,890 In the 8's
FY1TA
In the 8's
Media doesn't remove any rust . Dipping removes it all . I have cars that were dipped 8 years ago without issue . The most important thing is to get them clean after dipping and use plenty of epoxy primer . here is a pic of TA340's car after paint .
[Re: FY1TA]
#592278
01/31/10 05:51 PM
01/31/10 05:51 PM
Posts: 1,572 Jacksonville Florida
elitecustombody
lol,who told you media is plastic? There are many types of media,and it does remove rust
Here are some types of blasting media :corn cob,glass bead,pumice,ceramic shot,stainless cut wire,steel shot,walnut shells,steel grit,aluminum oxide,silicon carbide,crushed glass,plastic media and more
[Re: elitecustombody]
#592279
01/31/10 06:39 PM
01/31/10 06:39 PM
FY1TA
In the 8's
Well excuse me . Plastic around here is called media .
