Re: 360 backfiring through carb and exhaust
[Re: MattAman]
#592201
02/06/10 11:40 AM
02/06/10 11:40 AM
RapidRobert
warm is ideal and gives you the highest readings but a cold test will for sure suffice here as we are seeking a cyl that is not doing it's job (for one reason or another)so we can rule out the long block so the variations and of much less concern the total will tell us if your long block is healthy. EDIT be sure to block the choke and the throttle all the way wide open
[Re: MattAman]
#592203
02/06/10 03:14 PM
02/06/10 03:14 PM
RapidRobert
Do it as is & lets see what you got. Pull the plugs and if a helper is using the key to crank it take off the pentastar ECU connector. Let er rip & post some #'s.
[Re: MoparforLife]
#592213
02/10/10 10:04 AM
02/10/10 10:04 AM
Posts: 28 PA.
340rocks
PA.
nobody mention ing coil Ihave msd coil #8253 on my 340 backfired one day stalled got it restared ran poorly started to smoke from tailpipes changed msd box didnt work changed coil was back to normal when it backfired blowed out Intake gsks. your Comp readings are fine I did same ckd .comp readings were 35psi off please try know good coil
[Re: dm69charger]
#592215
02/10/10 10:31 AM
02/10/10 10:31 AM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
I am with Andy F that some debri is probably caught in the carb. Especially if the car runs at higher RPM's with no problem. The debri is probably clogging up the transition circuit from off-idle.
I missed that and if this is right it almost has to be fuel related. This gas now days don't take long to gum things up.
