360 backfiring through carb and exhaust
#592176
01/24/10 12:32 AM
01/24/10 12:32 AM
MattAman
Hello,
I have a mildly built 360 in my 69 Valiant with MP electronic ignition. About a year ago, I was driving and the car suddenly backfired badly through the carb and then stalled. Luckily, I was a mile from the house and was able to get it fired again long enough to limp home. The car would idle but had no power and stalled when I released the clutch unless I kept the rpms high. It felt like I had dropped a couple cylinders but the idle sounded fine. As soon as I got in front of my house, it quit. I tried to restart it and it seemed to fire but then immediately cut off. My first instinct was to check all electrical/ignition components, which I have done, but haven't had any luck. I swapped out the cap, rotor, wires, orange box, and finally the distributor. I can get the car to start up and idle, but it still has no power when you release the clutch and backfires through the carb and exhaust. The timing checks out fine when idling and all my grounds are fine as well. When I fired it up today, a bunch of fluffy black material came flying out the tailpipes and the carb caught on fire. Any thoughts on what could be wrong? I am worried it might be a valvetrain issue, but wanted to see if anyone had other ideas.
Thanks for the help!
Re: 360 backfiring through carb and exhaust
[Re: MattAman]
#592178
01/24/10 12:53 AM
01/24/10 12:53 AM
RapidRobert
major vac leak EDIT you know it sounds like (to me) classic ECU failure but I discounted that when I posted as you replaced the orange box but I wonder if it's possible the new one is bad also?
[Re: RapidRobert]
#592179
01/24/10 01:57 AM
01/24/10 01:57 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
i would have had the valve covers off and see that all the rockers and pushrods are in the right place....and that all the rockers go up and down went the engine is cranked...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: MattAman]
#592180
01/24/10 04:43 AM
01/24/10 04:43 AM
Posts: 511 Jasper, Indiana
fastnos
Jasper, Indiana
Any chance it jumped timing? Does your timing mark jump around much at idle? If it jumped a tooth or two, That could explain the backfiring and loss of power? With a timing light, if it jumps around a lot, I'd check that, after verifying the fuel/power valve was still good. What do your current plugs look like?
A True Hybrid: Burns Gas AND Rubber!
[Re: Dodgem]
#592184
01/24/10 12:04 PM
01/24/10 12:04 PM
Posts: 15,491 the boonies
aarcuda
the boonies
didnt see what carb, but if its a holley, change out the PV.
next idea is jumped timing chain or wiped cam or bent pushrods????
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
[Re: aarcuda]
#592185
01/24/10 01:14 PM
01/24/10 01:14 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
Head gasket leaking between cylinders??? Seen this often. Compression or leak down test time it sounds like to me.
If you like drag racing, support your local track.
[Re: MattAman]
#592194
01/24/10 09:50 PM
01/24/10 09:50 PM
aarcuda
the boonies
with the valve covers off, see if you see any noticeable difference in the valve height when they are open. turn the motor over and try an compare the lift on all the valves. may be subtle. maybe be really big (1/4 inch)
